Ringing noise. Clutch??
Old Jul 22, 2015 | 01:13 PM
cbasan22's Avatar
2005 5.9 24v 6 speed. Truck makes a ringing noise at startup untill warm. If I push the clutch in the noise goes away, when the clutch is released the noise returns. I do not hear it when driving mostly at idle and when the truck is warm it seams to go away. The best way to describe the noise is it is similar to the ring when you run your finger around a wine glass. It does not seam to effect the truck. Is this something to worry about right away? Any info helps. Thanks
Old Jul 22, 2015 | 05:22 PM
bobsallyh's Avatar
During the "cold months" 40-55 degrees in Yuma, AZ. this past winter, I had a squeal at start up when I had the clutch pedal depressed. Almost immediately it would go away and sometimes would come and go for minute when pushing the clutch pedal in. When the temperature warmed up 60 plus degrees it disappeared. Fast forward to May, pulled into fuel at Wells, NV. Then it was squealing like a piggy. Went on to Twin Falls ID. to an RV park and it was louder and lasted longer. I figured it was the throwout bearing and it was. New clutch kit took care of it.
2003 6 speed 189,000 miles
Old Jul 22, 2015 | 10:31 PM
rockcrawler304's Avatar
Sounds like the throw out bearing for sure.
Muchacha27
Jun 11, 2011 09:51 PM
BTM
Jul 5, 2010 12:29 PM
swank
Nov 24, 2004 08:25 AM
TXram
Nov 8, 2004 08:15 PM
GO 4LO
19
May 5, 2004 03:25 PM
