Ringing sound from clutch?
Old Jul 3, 2010 | 09:58 PM
BTM's Avatar
BTM
Hi, everytime I load the truck heavy, I hear a steady on & off ringing sound from the trans. or clutch. I have the bed filled with sand and gravel. When I let off of the clutch, until it revs up a little, it's a steady beat of bing bing bing bing bing bing until the rpm's get up. Empty, the clutch doesn't slip and drives relatively good. It has always done this even before I had the clutch replaced. Any ideas? Thanks, Rich
Old Jul 4, 2010 | 01:00 AM
93flatbed's Avatar
I'd lean more tword a trans noise. Those getrags will make some noise when being used as a truck, well at least mine did. My 4500 makes some noise also while towing way to much also. have you overfilled the trans with some good fluid?
Old Jul 4, 2010 | 07:34 AM
This is in any gear or just starting off?
Old Jul 5, 2010 | 12:29 PM
BTM's Avatar
BTM
I have overfilled the trans. Yes, it does it in the first four gears. It did it before I had the clutch replaced also. It does pull it without alot of effort, just makes that silly ringing noise. Rich
cbasan22
Jul 22, 2015 10:31 PM
2whistlers
Jan 21, 2005 09:52 AM
swank
Nov 24, 2004 08:25 AM
TXram
Nov 8, 2004 08:15 PM
GO 4LO
19
May 5, 2004 03:25 PM
