replacing rotors on 2003 3500 DRW 2wd.
Old Oct 1, 2006 | 07:36 PM
dieselfan's Avatar
how hard is it to change the rotors on a 03 3500 2wd DRW?
i need to change the rotors and pads on my dads truck.
i plan on going with some brembo rotors from tirerack and i m unsure of the pads, any suggestions or tips?
thanks dieselfan
Old Oct 1, 2006 | 07:46 PM
dodgetech77's Avatar
Easy pull the wheel,unbolt the adapters remove caliper and slide the rotor off
Old Oct 1, 2006 | 08:05 PM
dieselfan's Avatar
thanks, thats what i figured, just wanted to check before i started.
any special tools?
thanks , dieselfan
Old Oct 2, 2006 | 02:14 AM
Mike B's Avatar
Unbolt the adapters? I was looking at that too but you cannot fit a socket in there. What concerns me is that by using a wrench, how would you know what the torque spec is the bolt that holds onto the adapters?
Old Oct 2, 2006 | 03:27 AM
XLR8R's Avatar
Choose softer pads for longer life on the rotors, or plan on replacing the rotors if you buy the harder pads with the lifetime warranty... on my '98, I bought lifetime pads AND rotors - I don't worry about the maintenance time, 'cause I have my son do it.
whitepowertruck
Sep 6, 2013 06:39 PM
jlipskoc
Mar 7, 2009 08:00 PM
04ctd
Aug 3, 2007 04:19 AM
DeadAtTheWheel
Apr 30, 2007 04:21 PM
BigBlue
Jan 5, 2006 08:44 PM
