rebuilding 5.9 40 over to much?
Old Sep 2, 2016 | 11:23 AM
tigerhays's Avatar
I lost a seat in my 5.9 cummins 03 block,it scratched the cylinder wall...may have to bore 40 over? Is there a negative to that if it doesn't make 20?
Old Sep 2, 2016 | 11:32 AM
tigerhays's Avatar
I have compound turbos....I do not run it hard,it has been used for towing...
Old Sep 2, 2016 | 01:00 PM
ColeRollington's Avatar
You'll gain a whopping .1L of displacement, so there's that.
The general consensus is that .040" is the limit on these blocks, after which you'll need to sleeve the cylinders.
Boring the cylinders makes them slightly weaker, keep that in consideration.
You should be ok if you're not racing around, rolling coal on everybody.
TxDiesel007
Feb 18, 2007 10:42 PM
Tank_66
18
Dec 31, 2006 02:15 PM
ktpul
Feb 13, 2006 08:01 PM
MCMLV
Oct 7, 2004 06:11 PM
bigfoot
Aug 14, 2004 02:22 PM
