rear main seal
Old Oct 25, 2009 | 02:19 PM
Secondrate's Avatar
rear main seal
Where would the oil come out of if that seal was going out and how hard is it to change or how much is it to get changed thank you
Old Oct 25, 2009 | 03:58 PM
Jeff in TD's Avatar
I would expect oil out of the bottom of the bellhousing.
Replacing it looks pretty straight forward, once you pull the transmission and flywheel.
Old Oct 25, 2009 | 05:14 PM
Sandaholic's Avatar
As long as you have no problem pulling the trans the actual replacement of the seal is a piece of cake.
Old Oct 25, 2009 | 05:23 PM
Secondrate's Avatar
does pulling the fly wheel mean taking the clutch off of it first
Old Oct 25, 2009 | 05:34 PM
Sandaholic's Avatar
Yep. You'd have to.
Pull the drivelines
Drop the t-case
Pull the trans
Remove clutch
Remove Flywheel
And there's the rear main staring you in the face
Good time to upgrade to a dd or a triple
Old Oct 25, 2009 | 06:03 PM
Secondrate's Avatar
thats not cool i already have a nice single that holds pretty good but the whole messing with the clutch kinda scares me its not leeking to bad i just noticed it wiped it off and ill see how long it takes to leak back down i guess
Old Oct 25, 2009 | 06:38 PM
Sandaholic's Avatar
My rear main was leaking, but I could never tell because of my blow-by tube. Every once in a while I spew a little oil out of the tube and it would end up dripping down right near the slot at the front of the bellhousing. Do you have your blow-by tube extended? I still need to extend mine. BTW I don't think my seal was leaking all that bad. If you had one leaking really bad I suppose it would be possible for the oil to get onto the clutch disc. It could fling up and then drip down. That wouldn't be good if a guy had a disc with organic facings. Probably not good for the other type's either, but that's just speculation on my part. I think my rear main seal leakage might have helped contribute to my clutch's death..........well that and my Smarty
Old Oct 25, 2009 | 10:22 PM
NickBeek's Avatar
I thought I had a rear main seal leaking, when I looked closer it was the oil pan gasket leaking right in front of the bell housing and getting blown back.
Old Oct 25, 2009 | 10:38 PM
Spooler's Avatar
Also, check the rockerbox at the back. They are prone to leak there also and most of the time that is where it comes from. Always start from the top and work your way down while trying to find an oil leak.
Old Oct 25, 2009 | 11:38 PM
Sandaholic's Avatar
Good call.
Old Oct 26, 2009 | 03:43 AM
nwflyoda's Avatar
i thought mine was leaking but it turned out to be a few bolts that were a little lose on the oil pan.
Old Oct 26, 2009 | 10:47 PM
Secondrate's Avatar
Well It's In The Shop Now They Said Warrenty Just In Time It's Got 99965 Cutting It Pretty Close But Just I'm Time
ted_pulliam
Aug 4, 2010 11:33 AM
bnold
Jul 7, 2007 06:18 PM
chaikwa
Mar 24, 2004 09:23 PM
okcummins
Dec 21, 2003 07:45 PM
Mostwanted
Sep 17, 2003 06:55 AM
