rear main seal???
Old Dec 20, 2003 | 03:03 AM
okcummins's Avatar
rear main seal???
I have a rear main seal leaking at 270,000 miles and my question is do thes seals wear and leak or is there a big chance I'm going to find bigger problem when I get in there?
Old Dec 20, 2003 | 07:01 AM
Dieseldude4x4's Avatar
Re:rear main seal???
The seal started leaking on my 89 at about 120000. I had a fellow up the road that is pretty reliable go in and replace it. It is a double lipped teflon seal and must be installed DRY. He din't believe that but I copied the service manual on seal replacement and took it to him. As best I remember, the seal was about $80 from Cummins. He replaced it and no further problems.
Old Dec 20, 2003 | 08:22 AM
kandgo's Avatar
You made it 70k farther than my 91 1ton before leaking,I went ahead and done a clutch job on mine when down,it is not a difficult job,if you have a place to do it in out of the weather. As above I could not believe that it went in dry,mine was really tight and somewhat of a booger to get in,but it finally does, Goodluck Rick
Old Dec 20, 2003 | 10:08 AM
Redleg's Avatar
$80 and labor will pay for a lot of oil. Is it a Real bad leak? Mine drips, but I'm waiting to see how a couple other projects are gonna go so I can tackle it at the same time.
Old Dec 20, 2003 | 04:14 PM
Ruralmedic's Avatar
If it is possibly leaking from a build up of contaminants and sludge around the seal, I would suggest visiting www.AutoRX.com I am not one to put faith in oil additives, but tried this on a seal leaky gas engine of mine, and it stopped the leak.
It's actually a metal cleaner that uses the engine oil as the carrier, and slowy cleans build up inside the engine. The stuff isn't cheap, but less expensive than replacing the seal. Of course, though, you will not find out if the seal is ripped or torn until you run a cycle of this stuff.
I am NOT afilliated with this company.
Old Dec 20, 2003 | 04:24 PM
okcummins's Avatar
I guess I'll go ahead and do it myself pulling a tranny isn't to tough on 2wd it should save me some money. I was just wonedring how long the main shaft bearings last. Sometimes a leaking seal is a sign of bearing failure.
Old Dec 20, 2003 | 06:43 PM
thumper 549's Avatar
the m.s. are prone to looking bad but the good news it ez to replace along with everything else while you there
main seal
fork, t.o. bng. and take a good look at your cam and oil gally plugs (they can be a cause for a drible also)
Old Dec 21, 2003 | 07:11 PM
torquefan's Avatar
On the early Dodges, the outside of the seal was metal, and the seal would actually work loose from the engine, and some would start to fall apart. The new seals now have rubber ribs on the OD and they seem to stay put a lot better.
Old Dec 21, 2003 | 07:45 PM
Cumminsdude's Avatar
If you still need the seal, I came across one on ebay today.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2449204712
Hurry and you may be able to get it fairly cheap.
ted_pulliam
Aug 4, 2010 11:33 AM
bnold
Jul 7, 2007 06:18 PM
DOGOMAN
Aug 11, 2004 06:02 PM
chaikwa
Mar 24, 2004 09:23 PM
Mostwanted
Sep 17, 2003 06:55 AM
