2003 pistons in 2006 5.9?
Will the pistons from the 2003 engine fit on the rods of a 2006 5.9?
Will it change the displacement?
Is there any other problems you can think of?
Anyone have the cost of the pistons/rings?
They will fit but you can't use them. Piston bowls are different for the different spray angles of the injector tips. No worky.
Not sure on the compression but just guessing maybe 1/2 a point due to the bowl configuration. Other impacts due to the timing and funky valve profile is unknown. Change out the cam and that is moot.
The 03/04 injector tips have 8 holes vs 5 holes for the 04.5+ years. The 03/04 tips also have a wider spray angle than the newer trucks, which prevents the 03/04 trucks from utilizing more advance timing, without spraying outside the piston bowl.
I would not do it, the third injection event and other factors on the 06, just do not make for a good mix with the earlier pistons.
JUST replacing the pistons will NOT work without catastrophic results. Thats a given. No info on the benefits of doing this that I have seen. That thread you referenced has more than few flags about what happens if you don't do it right also. Gotta look at the big picture and not just a piece of it unless rebuilding the engine is a hobby one likes to do frequently.
The 3rd injection event isn't really an issue - and the ECM can be swapped if you believe it matters (works fine either way). Camshafts aren't different.
The 555 motor's re-entrant injector tip & piston bowl design are proven to make more power than the 610 series... and Cummins switched back to re-entrant spray geometry on the 6.7L for good reason.
Not much reason to interchange parts for the average rebuild or daily driver, though.
Re-entrant bowl design was developed in response to emissions and is still used to achieve that end. Past a certain point it is actually detrimental as the lip ends up being the start of hot spots and cracking. The Duramax uses this design and they have way more problems with pistons than the Cummins.
A re-entrant design relies a lot on valve placement and timing, injector spray pattern and number of holes to function efficiently. Change too many of those parameters and it ends being a detriment rather than help. In a large bore engine its an attempt to promote better mixing of the air\fuel. Theoretically that will make more power but the constraints are a lot tighter on how much and the conditions that promote the power.
I have got to ask for you to please clarify the difference between theoretically and empirically on the 555 versus the 610. Really would like a schooling if you got the time....
You mean geometry differences?
'03-'04 piston dome 113*
fuel injector spray 143*
'04.5-'07 piston dome 140*
fuel injector spray 124*
or fueling differences?
i.e.
555's make best power with F6.X sticks
610's make best power with F5.X sticks.
or the ECM?
3rd injection event has been shown to have an insignificant effect on power production.
or ???
There are a few differences between them that favor the 610 motors - such as the ability to run more timing due to the spray/dome angles - but they are apparently outweighed by the re-entrant design's superior efficiency.
Re-entrant vs. non re-entrant theory is another discussion.
i.e.
or the ECM?
or ???
Thanks for the numbers difference on the piston geometry, never knew that. I have held the two types in my hand and noticed the 03/04 are a deeper cut into the bowl, I think. I'm going out on a limb here but.... is this why the 555 doesn.t like as much timing as the 600/610 piston. Why, in your opinion, did cummins/mopar change the injector hole geometry from 8 holes/555 to 5 holes/600-610. Yes they improved the emissions out the pipe with a cat, but why did it increase the torque and horsepower? Thanks for the reply dude, great info
DodgeRam24V
13
10-27-2011 11:28 PM
Dan Marino
09-28-2009 03:51 PM
ddestruel
05-10-2005 12:17 AM
