1st gen pistons vs 2nd gen pistons
Old May 28, 2009 | 06:47 PM
RollinCoalSmoke's Avatar
Stumbled across a new "in the crate" 2nd gen short block today. What's the difference in the blocks, pistons ect. vs the 1st gen ? Somewhere I think I read where the piston were the only difference???? Is this correct or not? Thanks for your input.
Old May 28, 2009 | 06:53 PM
As long as it's a 12 valve shortblock there is no reason you can't use it.
Old May 28, 2009 | 07:25 PM
It is supposed to be, it was purchased to replace a shortblock in a 96 12v. The guy was taking the truck to the shop to have it replaced and got T-boned and totaled out the truck. The engine was never unwrapped until today when I got it home, it's been setting in his shop/barn since 02. No rust in the cylinders or even on the deck surface. Was well preserved.
Old May 28, 2009 | 07:52 PM
Riflemanusmc's Avatar
Registered user
Blocks,rods,crank are the same. There is a change in the first GEN non I/C vs.Non I/C pistons.. Bowl in the piston changed...Spray pattern of the injector.. 2nd GEN, you do mean a 12V block correct?
Old May 29, 2009 | 01:02 AM
Philip's Avatar
I have been told on another site that the IC 1st gens and the 96/98 2nd gens used the same spray angles. The nonIC and the 94/95 2nd gen's had the same spray angles.
Old May 29, 2009 | 09:20 PM
Registered user
The bowl in the top of the piston is differant. Non I/C piston has a bigger but the dowl is bigger/wider on the top. Do a search on I/C vs non I/C. VE vs P7100 pump pistons. The I/C pistons are a differant number. As far as what you have read.. Coudn't tell you. Look up Cummins numbers on then.....
BRUISER
Feb 2, 2015 11:25 AM
DodgeRam24V
13
Oct 27, 2011 11:28 PM
77machomopar
Jul 15, 2009 04:56 AM
skynyrd
Jan 10, 2008 06:41 AM
ddestruel
May 10, 2005 12:17 AM
