Rear main leak
Old Jul 24, 2013 | 03:37 PM
railroaderone's Avatar
Rear main leak
I replaced the rear mAin seal on my engine when i was replacing the clutch the first seal started leaking within two days due to a defective seal out of the box, I had a shop change out the second one due to time constraints made it a little over a week and its leaking again. I used the improved Fel pro seal both times anybody have any ideas on a better seal? Thanks in advance
Old Jul 24, 2013 | 07:59 PM
jhenson's Avatar
Are you sure it's the rear main and not the cam seal?
Old Jul 25, 2013 | 10:48 AM
johnh's Avatar
cummins rear main seals don't leak very often, it could be leaking from some where else
Old Jul 25, 2013 | 12:42 PM
banyon's Avatar
I used the seal from cummins. I gave the parts guy my engine number & it's been good for two years. Are you sure there's not a nick on the crank or something? I think this is a common problem, (rear main leaking). I seem to have read when I put mine in that it was a bad batch of seals from the factory. Of course mine didn't leak until it was out of warranty. Good luck
Old Jul 25, 2013 | 04:36 PM
jhenson's Avatar
My engine has almost 312k miles on it and each time I pull the tranny to put a new clutch in it (power is a great thing but it's heck on parts) I have to replace the leaking cam seal.....never the rear main.
Old Jul 27, 2013 | 08:44 AM
Where is the cam seal located in relation to the stArter
Old Jul 29, 2013 | 08:22 AM
jhenson's Avatar
Looking at rear of engine it's up towards the top. You'll have to pull the aluminum cover off of backside of block to access it. It resides behind a small inspection cover.
Old Jul 29, 2013 | 07:35 PM
Behind the trans adapter?
Old Jul 31, 2013 | 08:02 AM
jhenson's Avatar
Sorry for the late replies.....been too tired and busy to even turn the pooter on. Yes, it's behind the trans adapter.
Old Jul 31, 2013 | 06:00 PM
Great gota remove it all again
truk
Jan 20, 2007 10:04 AM
MJDiesel
Feb 27, 2006 06:34 PM
TXTad
Jan 17, 2006 01:14 PM
rebal
Nov 6, 2005 06:34 PM
robert chilton
Sep 10, 2004 06:37 PM
