rear main leak
Old Nov 4, 2005 | 08:24 PM
rebal's Avatar
rear main leak
my 01 HO 6spd is leaking purdy good out the main seal does ant one know what its costs to get it fixed, and ill prolly do a sbc con ofe while in there?
is this a diff job to do myself???
Old Nov 5, 2005 | 06:29 PM
rich's Avatar
Its not hard to do if you have some mechanical skills takes about a day. Cummins makes a kit to fix it. My old 98 had a leak come to find out it was the cam plug so check that also when you have it apart. you have dropp the bell housing to get to it all and remove the starter too.
Old Nov 6, 2005 | 10:24 AM
tmleadr03's Avatar
The seal itself isnt that expensive but if you take it to a shop or a dealership it will run you about 8 hours labor (changing a oil pan gasket is 7.3 hours labor and 30 bucks in parts, I figure rear main seal is about the same).
Doing it yourself isnt that hard, but you have to drop the tranny, there are a few good threads recently about how to go about doing that.
Old Nov 6, 2005 | 06:34 PM
rebal's Avatar
thanks guys ill order a SBC and start in on it
trik396
Feb 11, 2007 02:21 AM
truk
Jan 20, 2007 10:04 AM
MJDiesel
Feb 27, 2006 06:34 PM
TXTad
Jan 17, 2006 01:14 PM
robert chilton
Sep 10, 2004 06:37 PM
