Quick question!!
Old Feb 26, 2006 | 11:08 AM
odie2219's Avatar
Quick question!!
I just serviced my "uni" air filter (cleaned , oiled and reinstalled). After starting , I got code 0191 (fuel pressure sensor). My qustion is, would this throw this code? I also replaced the torque tube back to stock.
Thanks
Odie
Old Feb 26, 2006 | 11:10 AM
Dodgezilla's Avatar
You didn't start it up with the Air temp sensor still unplugged, did you?
Old Feb 26, 2006 | 11:38 AM
odie2219's Avatar
I just double checked, and the sensor is attached.
Old Feb 26, 2006 | 12:10 PM
CRXsi's Avatar
Chances are it is completely coincidental and has no relation tot he air filter...it does sound like maybe you are due for a new lift pump however?
That code is for the fuel pressure sensor mounted on the hp fuel rail. It is on the drivers side of the intake manifold to the rear of the intake opening. Maybe just double check to make sure that your electrical connections are good and corrosion free...otherwise either the sensor failed or there isn't enough fuel or fuel pressure in to make the sensor read properly.
Old Feb 26, 2006 | 12:46 PM
odie2219's Avatar
Thank for the quick responses!!
odie
HorseHauler
13
Mar 12, 2006 11:48 AM
WSUcougars
Dec 14, 2003 08:52 PM
hellotbone
18
Jun 25, 2003 01:16 PM
dieselcrazy
Feb 15, 2003 06:44 AM
soundbrz
Nov 19, 2002 11:36 PM
