Question about Dodge recall
I know there's a recall regarding steering on our trucks. I had my inspected and they said nothing wrong with it. Recently I've been hearing a metal clacking sound every once in awhile and can't locate it. It doesn't do it frequently enough to figure out where it's coming from, but yesterday I got under the front end and hit the tie rod with my hand and heard a sound similar. If I hit the tie rod with just my hand I hear the sound and it seems to be coming from the steering box or the turnbuckle thing for the tie rod adjustment. Is this somewhat normal? Also when I was under the truck I can actually move the transmission mount about 1/2 inch as I watch the bushing deflect, is there supposed to be movement that freely in the mount?
Hard to say what that specific noise is, but regardless of whether Dodge says you need parts or not, you do.
Get the '08 steering linkage upgrade and you'll be much better off. If you do a search on this you'll get lots of info. It involves the linkage, the pitman arm and the damper as three separate parts, not a kit, and it bolts right on to any earlier third gen. Also, the track bar bushings and the ball joints should be checked and/or replaced. But the steering linkage is a must in my book. It's much stronger than the stock setup.
While you are under there checking, hit the sway bar end links with your hand and see if they clack. They're a known noise maker.
I agree w/ everything Raspy said, and thought of one more thing for you to check J.
Put a wrench on the front shock mounts. Use a breaker bar, and really give them a good torque. If you type front end noise or clunk into the search bar you will find many have solved their clunk issues by tightening the front shock mounts.
Again, if this is not your issue pursue the steering linkage.
Scott
Scott
Yeah I was going to get under there and tighten everything up again just to make sure. I'll check into the steering upgrade. Is there a place other than dodge that sells it? pretty sure dodge will want my left arm or leg..
when i got that recall they just took my vin number. to where as on my dads 03 thay crawled underneath and looked at it. so are they making easy money off me just by taking my vin. the recall sheet had my vin so why would they write it down. iasked are you going to look and he said no.
james satterfie
Dec 14, 2004 08:35 PM
