Pulse in #1 & #4 fuel line...Normal?
Old May 25, 2012 | 08:41 PM
MX429's Avatar
After changing a fuel filter today, I cranked the truck and had it at idle making sure everything was ok. I have had the #4 line break before, so I looked at the fuel lines to make sure all the isolators were tight and in place. As I touched each fuel line I noticed something. The #1 and the #4 line have a pulse when you touch them that the other lines dont seem to have.
Is this normal? A sign of bad things to come? Edited for content Nothing to worry about? End of times?
Please do not use symbols for profanity. Thanks madhat
Old May 25, 2012 | 09:57 PM
Spooler's Avatar
Yes, it is normal and nothing to worry about.
Old May 26, 2012 | 09:44 AM
MX429's Avatar
With the pulse, I can see why #4 would be prone to having the isolator become loose.
Old May 26, 2012 | 10:35 AM
06RAM2500's Avatar
#1 yes, #4 no. Need to re-tighten the clamp as soon as possible.
Old May 26, 2012 | 10:55 AM
BigIron70's Avatar
Cummins Guru
If you replace the #4 fuel line I would also retighten bolt and use loctite on it. I replaced the#4 line and it came loose again and the line cracked. Mopar claim the line but just a heads up that they will loosen up again in short period of time.
redneck2thamax
Jan 25, 2010 07:00 PM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
Tommy93w350
Aug 7, 2007 12:15 PM
plow
Jun 4, 2005 11:48 PM
