pulse in fuel lines
Old Jun 3, 2005 | 03:17 PM
plow's Avatar
pulse in fuel lines
when i grab hold of my rubber fuel lines coming from tank the ones that run beside tranny and up to fuel filter, they pulsate is this normal.
Old Jun 3, 2005 | 04:15 PM
apache's Avatar
My 95 does this as well, I noticed it after replacing the lines. If I remember right the return was more noticable by far.
Old Jun 3, 2005 | 04:23 PM
SoTexRattler's Avatar
Yep, its normal....
The "lift pump" on a 12valver is a camshaft driven, positive displacement, plunger type pump. The P-7100 injection pump has a spring loaded backpressure valve called the "overflow valve" . It helps maintain proper fuel feed pressure to the inj pump . The excess fuel that isn't injected into the engine by the P-7100 is returned back to the tank through this OF valve.
The fuel supply and return lines can really pulsate from the fuel being pumped around.
Have yours hoses ever been replaced? Those OEM hoses can be a source of starting problems when they start deteriorating, getting soft and begin leaking a little air into the system.
K.
Old Jun 3, 2005 | 04:52 PM
plow's Avatar
no mine have never been replaced. If my fuel lines was getting air would this cause a low rpm noise? about 1800 seems to be the place it does it the worse.
Old Jun 4, 2005 | 11:48 PM
Noise?? No, I don't think so..
The most common complaint concerning rotten fuel lines is starting troubles.
Ya' let 'em sit for a while and air is drawn into the fuel system. Then you get to find out how good your batteries are!
Keith
MX429
May 26, 2012 10:55 AM
redneck2thamax
Jan 25, 2010 07:00 PM
MrKen
Feb 25, 2005 04:22 AM
hellotbone
Sep 1, 2003 08:46 PM
j
Dec 10, 2002 04:38 PM
