Priming Fuel System?
Old Dec 26, 2007 | 12:30 PM
Dieselhed's Avatar
Waiting on injectors to get here and everything is apart, I even removed the entire fuel rail to make things easier. I remember reading somewhere, and I can't remember where, about priming the fuel system before starting. How is this done? Just bumping the starter? Are there any special procedures I should know about before starting this thing?
Old Dec 26, 2007 | 12:33 PM
djbikeman's Avatar
Just bump the starter 2-3 times. The system is self priming. I am getting ready to do the same thing so I have read a ton of info on injector installs. The major no-no is opening the high pressure lines to and from the rail to prime them.
Old Dec 26, 2007 | 02:34 PM
Dieselhed's Avatar
You mean opening the high pressure lines to and from the rail to "bleed" them right? Other than that there is nothing? Man, this seems too easy.
Old Dec 26, 2007 | 03:39 PM
gmctd's Avatar
Try this: key ON - key Off - key ON - lift pump should run ~25 seconds for priming
Let me know if this works on the Dodge Diesel - does on other DCX products
Old Dec 26, 2007 | 09:34 PM
Dieselhed's Avatar
My Walbro doesn't run unless the starter is "bumped". My stocker was the same way.
Old Dec 27, 2007 | 08:10 AM
djbikeman's Avatar
That is what I meant. Sorru about that.
Ford_Ktm
Apr 8, 2009 09:36 PM
olwhitey
Jan 5, 2008 03:50 PM
SuperDave4x4
20
Jan 5, 2008 12:07 PM
nooska
Mar 6, 2006 07:24 AM
bigair
Apr 26, 2005 10:56 PM
