fuel priming?
Old Apr 26, 2005 | 08:25 PM
bigair's Avatar
fuel priming?
where is the primer for the fuel filter I've read all about but no body says where it is and I cant find it to save my life.thanks
Old Apr 26, 2005 | 08:52 PM
BoostdCTD's Avatar
It is just a little bulb, it is on the lift pump. Normally I cheat if I'm just changing the fuel filter I fill the filter with diesel then fire it up and run it at a fast idle until the air is purged.
Old Apr 26, 2005 | 09:00 PM
bigair's Avatar
I didnt have enough fuel to fill filter only about a quarter of the way. then I fired it it ran for about ten seconds then nothing. I am having one hell of a time getting fuel to pump.
Old Apr 26, 2005 | 09:52 PM
BoostdCTD's Avatar
Then I'd imagine you just air locked the pump, so break the bleeder screw loose and get the fuel to the IP by the little primer bulb then tighten that and break some (at least 3) injector lines loose. Turn the truck over until it stops foaming from those spots. Then once you tighten these nuts it should fire right up and run like nothing ever happened.
Old Apr 26, 2005 | 10:12 PM
Hemi Cat's Avatar
If you are working on a 94-98 12 valve, the primer is on the right side of the fuel pump. It has a rubber cover over the plunger. Just push it in to prime. If you have a pre 94, you have a lever on the side of the fuel pump that you push down to prime. Crack open the bleeder on top of the fuel filter, then on the overflow valve, towards front of pump between the pump and block. Then crack the inj lines, and crank the eng until you get fuel out the inj lines. Tighten up the line nuts and start it up.
Old Apr 26, 2005 | 10:56 PM
bulthisl's Avatar
All you need to do is crack bleeder on filter housing and pump primmer button [ I use a broom haddle and pump without reaching down in the engine ]
When fuel comes out there close bleeder.
then pump another 12~15 times or untill you hear overflow valve hum.
Then start truck with no probs.
But if you already have air in the injection lines it may have to crank a few turns and run rough for a few seconds.
: Eddie :
Ford_Ktm
Apr 8, 2009 09:36 PM
olwhitey
Jan 5, 2008 03:50 PM
SuperDave4x4
20
Jan 5, 2008 12:07 PM
Dieselhed
Dec 27, 2007 08:10 AM
nooska
Mar 6, 2006 07:24 AM
