Power steering fluid change
Old Jun 3, 2008 | 10:36 AM
DBLR's Avatar
Originally Posted by TexasCTD
Mopar ATF +4 is synthetic.
Mopar ATF is only a group III synthetic (a highly refined dino/crude oil that is legally allowed to be called synthetic) and not group IV (man made) synthetic like Amsoil an Redline make.
The paper noted that one alternative was to use synthetic Group IV base stock, which are even more expensive than the ATF+4 solution, which provided Group IV style performance from Group III stock. <-- This info is from the Allpar website. http://www.allpar.com/mopar/transmissions/fluids.html
Old Jun 3, 2008 | 01:00 PM
TexasCTD's Avatar
You may be correct that regular Mopar ATF +4 is not a "group IV". Honestly I don't know. I just know it's good stuff and has served me well.
It is what my owner's manual says to put in the PS reservoir. I wish I had thought to change out the fluid 70,000 miles ago.......but the original stuff that was in it still looked pretty good for 90,000 miles. But from now on im going to suck it out and replace it every 20k. Personally, I don't see any big need to spend more money on the Amsoil or Redline ATF +4. I am sure they will all work great though.
Old Jun 3, 2008 | 09:04 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
Originally Posted by dbossdiesel
This is actually good advice! I was trying to think of what else needed to be changed! Totally forgot about the PS! Thanks guys!
a great mind once told me, " PS fluid is the most overlooked fluid in all vehicles, ours helps with braking so you might keep a closer eye on it"
THANX, RowJ
Old Jun 3, 2008 | 09:50 PM
06RAM2500's Avatar
Remove a hose off of the cooler. I believe it's the bottom/inside hose. Keep dumping fluid into the res. until clean fluid comes out. This will flush the cooler. Start the truck and have a helper dump fluid into the res. until clean fluid comes out. This will flush the rest of the system. Re-attach the hose and refill the res. Work the steering wheel until all air is out of the system. Check the fluid level periodically. Use a syringe to suck access fluid out.
Old Jun 4, 2008 | 11:34 AM
elirandolph's Avatar
THANX, RowJ
I believe I was standing there when he said it. I never thought of it like that before. thanks rowj.
Old Jun 5, 2008 | 01:01 AM
TexasCTD's Avatar
I heard him say it too! That is what prompted me to put it into my 20K maintenance schedule. Thanks RowJ!
It's so easy to do, it's silly. Don't make it complicated. Just buy one of those cheap hand pumps from Autozone, suck out what you can, and replace with Mopar ATF+4.
Mark Hodowanec
Aug 24, 2009 07:55 AM
Tommy93w350
Jun 26, 2007 04:42 PM
CobraCTD
May 4, 2007 09:50 PM
herb
Dec 24, 2006 12:28 PM
amartinson
Oct 6, 2003 07:37 PM
