Power Steering Fluid Change?
Old Aug 23, 2009 | 08:36 AM
Mark Hodowanec's Avatar
Should the power steering fluid be changed periodically? My truck is 5 years old has 120K miles.
Old Aug 23, 2009 | 09:12 AM
bansh-eman's Avatar
I have never heard of changing your power steering fluid, just make sure it's topped off.
Old Aug 23, 2009 | 09:26 AM
Roperteacher's Avatar
At about 50,000 miles I sucked out all that was in the reservoir with a turkey baster and just replaced with new fresh fluid. It wasn't a system drain but it sure can't hurt to Fresh'n things up a bit.
Old Aug 23, 2009 | 09:39 AM
AaronT's Avatar
Dodge Maintenance schedule Power Steering fluid change and flush is at 100, 000 miles.
I use a baster and suck out the resevoir every 2 years or so and replace with fresh ATF +4,
Old Aug 23, 2009 | 09:40 AM
MikeyB's Avatar
I use a baster and such out the resevoir every 2 years or so and replace with fresh ATF +4,
Pretty much the same here. It's easy to do.
MikeyB
Old Aug 23, 2009 | 10:46 AM
Megaramasaur's Avatar
Does it use ATF +4 or PS fluid?
Old Aug 23, 2009 | 11:28 AM
MikeyB's Avatar
ATF+4 for the power steering.
MikeyB
Old Aug 23, 2009 | 11:39 AM
D-Roc's Avatar
I just dropped the hoses. Gets more out.
Old Aug 23, 2009 | 04:04 PM
TexasCTD's Avatar
I use a turkey baster too......and suck it out and replace every 20K miles or so........with a host of other fluids/maintenance.
It's so easy to do, why not?
Then I just leave the old ATF in the baster and use it on the turkey....
Old Aug 23, 2009 | 09:22 PM
bansh-eman's Avatar
I bet that makes for a great Thanksgiving day meal for the mother in law lol
Old Aug 24, 2009 | 07:55 AM
92'1stGen's Avatar
I use the turkey baster method and change the fluid in the reservoir every 20k like TexasCTD. I figure if do it that often than it will never really get dirty. After the first 30k miles the fluid was only a slight bit darker than the new that went in. FYI, there is a screen at the bottom of the reservoir that you don't want to damage with the baster. Make sure you stick the baster in there ever so carefully so as not to puncture the screen. It's closer to the bottom and I didn't have any problems while being cautious. I also take the reservoir cap off and clean it in a dish soap/water solution so that I know the vent is always working properly. If it isn't working properly than the cap might blow off the reservoir if the fluid gets hot, or worse. This is more a problem with people who run bigger tires though, with stock tires there shouldn't be a problem.
D-Roc
20
Jun 5, 2008 01:01 AM
Tommy93w350
Jun 26, 2007 04:42 PM
CobraCTD
May 4, 2007 09:50 PM
herb
Dec 24, 2006 12:28 PM
amartinson
Oct 6, 2003 07:37 PM
