Power Steering Fluid Change
Old Oct 5, 2003 | 08:38 AM
amartinson's Avatar
I want to change my power steering fluid to Amsoil (all other fluids done) and I'm looking for some ideas on how to do a complete fluid change at home. I don't want to do the old "turkey baster" and refill method unless I have to. I have some ideas of my own but I'm asking to see if anyone has a better way. Also, I assume I will use Amsoil Universal ATF unless someone convinces me otherwise. Thanks in advance!
Old Oct 6, 2003 | 01:28 AM
Haulin_in_Dixie's Avatar
Re:Power Steering Fluid Change
Not supposed to use ATF in the power steering, too much detergent or something, supposed to make it leak.
Old Oct 6, 2003 | 09:47 AM
JStull's Avatar
valvoline synpower.
-Jason
Old Oct 6, 2003 | 07:37 PM
bulabula's Avatar
Haven't done it on a Dodge Ram, but on a few other cars. It helps to have a helper and some extra fluid available too.
I jacked front wheels off the ground; removed the return line from pump reservoir and put it into a bucket; plugged the resulting hole in the reservoir; started the engine and have the helper turn the steering wheel back and forth while you pour the fresh fluid into the pump.
Stop when the fluid running into the bucket is clean. Button it all back together, check the level and clean up the mess you probably made.
I've done the turkey baster method too; both have thier disadvantages.
Mark Hodowanec
Aug 24, 2009 07:55 AM
D-Roc
20
Jun 5, 2008 01:01 AM
Tommy93w350
Jun 26, 2007 04:42 PM
CobraCTD
May 4, 2007 09:50 PM
herb
Dec 24, 2006 12:28 PM
