Poor Boy Transmission Mod
Old Nov 7, 2009 | 02:10 PM
shortie's Avatar
Hey folks it's hard times out there, heres a 25 dollar transmission mod that will really clean up your 2-3 shift in a 47 or 48 re for a couple hours labor and very little cost. Parts needed a sonnax oring intermediate servo cover and either a aluminum spacer available from pact for 5 bucks or if you really want to go low tech just use washers. Remove your pan and valve body, remove intermediate servo, remove c clip from servo and remove steel plunger and piston, remove orange oring from the steel piston and clean parts for reassembly.The aluminum spacer from pact or the appropriate washers go in first the idea being to remove the travel from the servo plunger. There is a small bleed hole in the servo piston by removing the orange oring the flow from the bleed hole will precharge the 2-3 shift circuit and speed up the 2-3 shift or bind up shift as bill kondolay refers to it. I have done this mod to several 47 and 48re and have been very pleased with the results uaually ending up with a much cleaner or crisper shift than with an aftermarket valve body.
Old Nov 7, 2009 | 06:48 PM
Lost Lake's Avatar
YIKES!!!
Not with my tranny..... It may work, but I'm not knowledgeable about these trannies, and I wouldn't do this kind of mod without learning the how and why and what-if about it....
I want to do something, just don't know what yet.
Old Nov 8, 2009 | 01:05 AM
DodgemnLeavem's Avatar
tell me more please, I have an 05 and its driving me nuts this darn shutter shift.
Old Nov 8, 2009 | 07:08 AM
navman28's Avatar
The Transgo shift kit improves shift firmness throughout the shift ranges.
Old Nov 8, 2009 | 08:30 AM
no_6_oh_no's Avatar
This is NOT a fix for the shuttle shift. Fix that first before maling other mods or you may have bigger issues.
Old Nov 8, 2009 | 07:56 PM
matt69olds's Avatar
Adding the spacer to the front servo defeats the "load-control" shift that Chrysler so lovingly engineered into the trans. It was added way back in the late 70s if I remember right. I dont like it, I like the shifts crisp and firm. I guess the had to do it to make the soccer moms happy!
Old Nov 9, 2009 | 09:36 PM
so adding the spacer will stop this then? I too like the shifts firm and crisp. thats what I want, I hate this slush box tranny. I wish now Id have waited for the Manual truck instead of getting this one. but thats not how things worked out.
Old Nov 10, 2009 | 06:01 AM
matt69olds's Avatar
yep, thats all it takes to defeat it.
Old Nov 10, 2009 | 01:13 PM
jballou's Avatar
Where is a good place to P/U ot order the load control servo spacer and servo?
Old Nov 10, 2009 | 02:08 PM
jimbo486's Avatar
if your tranny is "hunting" before shifting under light throttle, just push on the skinny pedal a little more. won't hunt anymore. local tranny guy has seen many trucks come in with that problem. the governor pressure solenoid isn't the problem. nor is the replacement of an aftermarket going to fix it. it's in the throttle motor and TCM. not sure if there's an update from dodge or not, but that may be the only permanent fix. i believe all of what he told me. he's driven all of the trucks that come in with the hunting issue, he steps on the throttle just a bit and it goes away.
Old Nov 10, 2009 | 03:58 PM
no_6_oh_no's Avatar
Incorrect, shuttle shift IS a failure of gov solenoid to set at what the ECU tells it based on output shaft speed and APPS. If it sets correctly and reacts correctly there is no shuttle shift.
The problem is there is little or no pressure rise right off idle and that contributes to the shuttle when things get worn because the gov solenoid cannot set fast enough. You can also make them shuttle shift by removing the TM and doing nothing else and that is a function of APPS position and output speed not matching paramters. That gets corrected with a shift enhancer.
Plenty of posts here and there on fixing shuttle shift and late shifting by replacing the gov solenoid and transducer with the aftermarket version. It is the only real fix.
Old Nov 10, 2009 | 11:49 PM
yeah but then we still have the soccer mom slush box shifts.I want this thing to chirp when going into 2nd gear.no slip just firm shifts I dont care how it feels, at least then I know when it shifts lol.
Old Nov 14, 2009 | 03:49 PM
shortie's Avatar
Should of done a little clarifying but was trying to keep the post short.
Most of the transmissions I have done this to had either aftermarket valve bodies or shift kits or at the least the line pressure raised.
If you have an after market billet servo you have already eliminated the cushion effect that the spacer removes just at a much higher cost hence the title POOR BOY. The leaving the oring out to precharge the 3rd gear circuit simply speeds the 2 to 3 shift leaving your transmission in the bind up phase for a much shorter period of time. For those that haven't studied the workings of these transmissions, third gear apply pressure and second gear release are the same oil circuit so both gears are trying to apply for the length of the shift, so anything you do to speed up this shift is an improvement.
Old Nov 21, 2009 | 03:29 PM
xxwildbillxx's Avatar
Any chance you might consider posting pics of the next 48re you modify!!!???
Old May 18, 2020 | 04:45 PM
aaron guenther's Avatar
Hey first time on this page but i have the same issue, 2-3 bind. I just rebuilt the tranny, but it did it before as well so I put the TCS accumulator and front servo in with the 4.2 lever and it's better but it's still there, I've tried band adjustment from 1.5 to 3.5 turns out and doesn't make a different, also changed out the valve body for another one so I'm lost, any input would be nice thanks. Also I don't quit understand what orange oring is being talked about in this forum??
Nate-03 D
Dec 21, 2006 04:14 PM
BigBlue
31
Nov 7, 2006 06:18 PM
rbattle
May 20, 2006 05:28 PM
Viesel
13
Sep 13, 2005 10:14 AM
PADZZ
May 24, 2003 09:57 AM
