Please help never seen this before....
Old May 27, 2009 | 01:33 PM
deepsouth06's Avatar
Sorry its long just want to be detailed so you can get the picture.
So this morning I started the truck and at the stop light out of my peripheral vision i noticed my rpm gauge make a small jump up and back down. Thought I was going crazy or man i must still be asleep. Didn't think anything of it cause truck totally normal, and i know I did not touch the go pedal. Anyways as I was driving to work it happened again and a lil more through the day. Truck feels normal than ever so I have no idea whats going on.
Is my rpm gauge going crazy. ....Guys i really need you help on this one, I have never seen this happen to any car I drive and its driving me crazy...
thanks.
Old May 27, 2009 | 04:17 PM
all these views and not one person can respond. Please a lil help
Old May 27, 2009 | 04:22 PM
nasty01cummims's Avatar
might be your apps. I kno mine did that when my apps went bad
Old May 27, 2009 | 07:12 PM
Moneywoes's Avatar
You have an 06
Without looking i knew you had an 06. tach jumping around but engine rpms aren't changing are they? Had my instrument cluster changed out at 24K miles doing the same thing. took them three days if i remember correctly they had to get one from star and it had to be programmed with the odometer reading on the old one.
Ken
Old May 27, 2009 | 09:20 PM
no_6_oh_no's Avatar
I hated to post and tell you but it sounds like the instrument cluster. You might try a crank position sensor but so far the problems like that have been a bad cluster controller.
Old May 28, 2009 | 10:31 AM
Peterbilt's Avatar
Check for any codes. Do cluster check. If you have been driving in the desert lately in the valley check for crud in the crank sensor.
Pete
Old May 29, 2009 | 01:08 PM
would checking for codes be the same as checking for engine codes? also where would the crank sensor be?
bigragu
Apr 7, 2007 12:07 AM
storx
Jul 17, 2006 08:19 PM
mymaur
Jan 14, 2003 08:29 PM
Tackdriver
Jan 9, 2003 06:11 PM
