Oil Pressure
Old Aug 26, 2010 | 04:15 PM
Canuckville's Avatar
Oil Pressure
Just got a quick question here on something tha I have been observing. My oil pressure gauge will drop low when idleing but when I step into it it will go to around 275 where it should be. Do any other guys experiance this on there 3rd gens? I known my 2nds gen it is constant no matter what it is doing. just want to know if there is something I should be looking at here.
Old Aug 26, 2010 | 04:47 PM
mitternocht's Avatar
The factory gauge is fake ran by the computer and will read in the red if you drop below a specified pressure, 5 PSI, I think.
Their programming isn’t bad for it generally follows what my real oil pressure gauge shows. At idle it will drop quite a bit, down to 20-25, when the RPMs rise so does the pressure, I think what you are seeing is normal, for either a real gauge or the factory fake one.
I assume 275 was a typo and you meant 75, 275PSI would indicate an issue
Old Aug 26, 2010 | 10:16 PM
TonyB's Avatar
On a real pressure gauge:
18-20psi hot, idle while towing.
45-60psi, depending on temp.
Tony
Old Aug 26, 2010 | 10:39 PM
Thundercraft's Avatar
No. He meant 275 as in 275 Kilo Pascals. He's from Canada and the trucks are marked in metric.
275 kilo Pascals = 40 pounds per square inch
Old Aug 27, 2010 | 04:49 AM
Thanks guys. I guess I have nothing to worry about. All is normal.
Old Aug 27, 2010 | 08:20 AM
CD in NM's Avatar
My oil pressure reading on the stock gauge fluctuates, when at idle it is about 12 o'clock (40) and at driving speeds it goes to 2-3 o'clock (60?).
I bought an oil pressure gauge so I can get an actual reading, the POS factory gauge is all but an idiot light, and it's response is a computer thing, not actual. If you had an oil pressure problem you'd be drained out before the gauge even hinted at a real problem taking place.
CD
Old Aug 27, 2010 | 08:45 AM
Fiftygrit's Avatar
Yup my 06 does the same thing, no problem.
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
