Oil Pressure
Old Jun 24, 2007 | 09:53 PM
gtstrkd's Avatar
Oil Pressure
What kind of oil pressure do your trucks run? I have purchased this new truck and it seems lower than what my 2nd gen ran.
Old Jun 24, 2007 | 11:00 PM
Wv7o's Avatar
My 06 5.9 runs at just above 40psi when warmed up at idle 36,000 miles on it.
Old Jun 25, 2007 | 10:07 AM
raycarlson's Avatar
Your oil pressure gauge is not telling you what your actual op is.It's only the ECM's estimate of what it thinks it should be.The only thing you op guage is actually telling you is that if you see any reading at all,that means you have at least 6psi.Which is what the op switch is set at which in turn closes the switch circut and the preprogramed parameters loaded into the ecm by DC engineers takes over your guage telling you what they think you should be experiencing in a normal cummins eng.read your electric diagrams nowhere in your truck is there an oil pressure sending unit, only the on-off switch.
Old Jun 25, 2007 | 11:20 AM
TonyB's Avatar
My oil pressure at idle will vary (depending on load, temp, etc) form 12-16. At 2500rpm, ~50psi. Cummins spec is >10psi at hot idle and >35psi at 2500rpm, hot.
Tony
Old Jun 25, 2007 | 01:35 PM
Bounce's Avatar
Why would they go to all that trouble instead of just using an acutal oil pressure sensor?
Old Jun 25, 2007 | 01:41 PM
Rob C's Avatar
Because some bean counter said it would be cheaper.
Old Jun 25, 2007 | 01:53 PM
ptgarcia's Avatar
I think it's because most people don't understand what they are looking at, and if they continuously see a gauge jumping all around it freaks them out. So like with coolant temp, it's pretty much a dummy gauge that shows low 40's p.s.i. all the time unless something is wrong. Its a shame too, because with a real gauge we may be able to foresee a catastrophic failure and take action to prevent it. With the factory gauge that won't happen.
On a side not, my Dad has a Porsche 911 and it has a "real" oil pressure gauge. It's fun watching that thing go up and down with RPM.
Old Jun 25, 2007 | 02:41 PM
Bounce's Avatar
Gotcha. They were over budget for sensors, but had software development budget left over, so they saved $0.06 per unit by using a switch, and spent $30,000 on developing and testing the software.
So typical.
What I wonder, is why include a gauge at all. If it's just a dummy gauge, then why not just have an idiot light and call it a day?
Wait...I know...because gauges look cool.
Old Jun 25, 2007 | 02:55 PM
ptgarcia's Avatar
For most people, appearance pulls a lot of weight.
Old Jun 25, 2007 | 04:17 PM
Bounce's Avatar
Yep. I doesn't matter if it works or not, as long as it looks good, they'll buy it.
Go bling or go home, baby.
Old Jun 25, 2007 | 08:06 PM
gtstrkd's Avatar
THanks for the info guys it is about right then. My 2nd gen just seemed to be higher
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
