Oil Pan Removal ?
Old May 31, 2012 | 11:53 AM
Dynocon's Avatar
Oil Pan Removal ?
Old pan rusted thru - new pan ordered.
I have read several post, is it possible to drop the pan, remove the oil tube and get the pan out without jacking the engine up?
Old Jun 3, 2012 | 05:21 PM
NickBeek's Avatar
I watched a dealer tech replace my oil pan gasket. He had to jack the engine up to clear the cross member that runs under the oil pan.
Old Jun 3, 2012 | 06:16 PM
DodgeRam24V's Avatar
i would say that is mission impossible
take a look, the pan is almost touching the cross member.
Old Jun 4, 2012 | 09:39 PM
barttly's Avatar
Hope you don't mind me asking about this same thing in your posting.
I've been wanting to do the same thing, and don't think I've seen a post that said you could do it without lifting.
My question, I only have a floor jack and not sure if you can jack up on the crankshaft dampener (I've always called this a harmonic balancer?) I read on another posting about the dampener/balancer maybe part rubber and lifting by it might cause damage? Not sure if this was referencing another vehicle? Anyone know for certain it's okay to jack from below and what is the best way to go about it. Okay enough about my specific question.
All the instructions in the manual talk about disconnecting the transmission to change the pan. I am under the impression this could mean just loosening the transmission at its cross member not actually separating the engine from the transmission?
Also, anyone know of some specific instructions on what is exactly necessary to disconnect to allow the engine to be lifted some. Sorry OP, just very curious about changing my pan too, I'm sure you have the same questions.
Again sorry to jump in here like this, but was prompted to post since I haven't posted in a long time. Then again someone might come along and say we can do it without lifting and we're both golden. not holding my breath on that though. Thanks.
Old Jun 5, 2012 | 07:27 PM
Dynocon's Avatar
The instructions I read said to remove the starter, fan shroud and loosen the engine mounts. Not sure about the trans. The more information the better.
Old Jun 5, 2012 | 08:33 PM
Contractor's Avatar
You will not get it off without lifting the engine, and there is another smaller crossmember (at least on an 06 there is) behind the pan. It has to come out down and back to come out. I was able to leave the tranny connected to the engine.
Old Jun 6, 2012 | 12:01 PM
Dynocon's Avatar
This is from ALLDATA for 4x4, 2005.
They show 4x4 and 4x2, some of the 4x4 install does not match up to the removal so please review and comment.
The 4x2 process looks like a lot more work, in additino it tells you to remove trans lines, propeller shaft, starter, torque converter bolts, exhaust hanger, gear shift cable, wire harness, trans mounts, bell housing, steering rack bolts.
Here is the 4x4 removal.
Disconnect Battery
Remove Air Intake Assy.
Remove Radiator Shroud Bolts.
Install Engine Support Fixture #8534B - Not sure what this is?
Raise and support vehicle.
Drain Oil
Loosen Front Engine mount Bolts
Lower Vehicle
Use Engine Support Fixture to Raise Engine
Remove Dip Stick
Remove pan bolts and lower pan.
Remove suction tube and pan.
Remove the 2 bolts from the front of the engine block stiffener.
Remove Pan.
Install
- Clean and reverse steps above.
Fill T-joint between the pan rail/gear housing and pan with Silicone rubber Adhesive Sealant. ???
Install new Tube to Block Gasket
Start with the oil pump inlet bolts - Tighten bolts to 18 FT*lbs, remaining tube brace bolts to 32 FT-lbs
Oil Pan bolts 21 FT*lbs, starting in the center working out.
Intall Dip Stick - Unless you him to help tightem bolts HA..HA
Intall Block Stiffiner
Install the flywheel to crankshaft adapter, torque to 101 FT*lbs? Not sure what this is unless it is something to do with the support fixture?
Lower Engine
Tighten mounts to 64 FT*lbs
Remove Fixture
Intall Battery Cables
Fill With Oil
Start / Check for Leaks
Remove Engine Support Fixture
Install the Fan and Fan Shroud. - Make sure the seal is properly seated.
Last but not least close the hood. Above did not say to remove??
Old Jun 6, 2012 | 12:49 PM
Dr.Dizzle's Avatar
The Miller Engine Support Fixture #8534B is what the dealer techs use to keep the engine on several vehicle brands supported while they perform drive train related procedures. They are expensive braces.
Old Jun 6, 2012 | 03:07 PM
BigIron70's Avatar
Cummins Guru
The only way I have been able to get oil pan off was removing transmission. Remove the flexplate and extenion housing. You still need to loosen motor mount bolts and raise engine up some to get oil pickup off. There are four bolts on the pickup tube, then remove pickup with oil pan. Pickup tube gastket usually will stick to the block. Just don't forget to drain oil first.
Old Jul 5, 2012 | 02:54 PM
rebal's Avatar
you can get the pan off with out pulling the trans. I removed the fan ,took intake tube off loosened motor mounts then raised the frame up so the axle will drop to full extension then juck the engine up till its out of the mounts the pan will fall out with out removing the pick up tube . this is on an 2006 4x4 auto
Old Jul 5, 2012 | 03:29 PM
Dynocon's Avatar
Originally Posted by rebal
you can get the pan off with out pulling the trans. I removed the fan ,took intake tube off loosened motor mounts then raised the frame up so the axle will drop to full extension then juck the engine uop till its out of the mounts the pan will fall out with out removing the pick up tube . this is on an 2006 4x4 auto
How did you lift the engine?
On my 2005 the cross member is the obstruction so lowering the axle does not help, is the 2006 different
Old Jul 5, 2012 | 04:17 PM
BigIron70's Avatar
Cummins Guru
Only on the 4X4
8534B - Fixture, Driveline Support
Click on the tool number to go to http://MillerSpecialTools.SPX.com for more tool information.
09 - Engine, 5.9L Diesel/Lubrication/PAN, Oil/Removal
REMOVAL
Labor Operations: Click to display a list of Labor Operations associated with this procedure
Special Tools: Click to display a list of tools used in this procedure
Click here to launch the form to order any tools you need.
Originally Shipped In Kit Number(s) 8534, 8534B, 8849, 9565.
4x4
1. Open the hood.
2. Disconnect the battery negative cables.
3. Remove the intake air assembly.
4. Remove the radiator shroud retaining bolts.
5. Install engine support fixture # 8534B .
6. Raise and support the vehicle.
WARNING: HOT OIL CAN CAUSE PERSONAL INJURY.
7. Drain the engine oil (Refer to 09 - Engine/Lubrication/OIL - Standard Procedure) .
8. Loosen the front engine mount bolts.
9. Lower the vehicle.
10. Use the engine support fixture # 8534B to raise engine out of the front mounts.
11. Remove the engine oil dipstick.
12. Raise and support the vehicle.
13. Remove oil pan bolts, break the pan to block seal, and lower pan slightly and remove oil suction tube fasteners.
14. Remove oil pan and suction tube.
15. Remove the 2 bolts from the front of the engine block stiffener.
16. Remove the oil pan.
4x2
1. Open the hood.
2. Remove the negative battery cables.
3. Raise and support the vehicle.
4. Remove the transmission oil cooler lines.
5. Remove the propeller shaft.
6. Remove the starter bolts.
7. Support the starter.
8. Remove the torque converter bolts.
9. Remove the exhaust hanger bolts.
10. Remove the gear shift cable.
11. Remove the wiring harness.
12. Remove the transmission mount.
13. Remove the crossover bolts.
14. Position the transmission jack.
15. Remove the bell housing bolts.
16. Remove the transmission.
17. Remove the flywheel housing bolts (8).
18. Remove the flex plate bolts (8).
19. Remove the engine oil dip stick.
20. Drain the oil.
21. Remove the steering rack bolts.
22. Remove the oil pan bolts.
23. Remove the oil pickup bolts.
24. Remove the oil pan.
Old Jul 5, 2012 | 04:29 PM
rebal's Avatar
I used an engine hoist .but if yours is a 2wd your in for a lot more work
05 06 are the same 4x4 are easy to do just rase the truck up and unload the suspension then raise the engine up with a hoist /forklift /something , use the lifting eye at the tstat .raise it up till the heater hose tube almost touches the cab once you have the bolts loose it will fall out on the ground if you let it
Old Jul 5, 2012 | 06:14 PM
Dynocon's Avatar
I am still not sure how unloading the suspension helps, are you sliding the pan towards the back of the truck?
Old Jul 6, 2012 | 07:37 AM
rebal's Avatar
the pan drops out the back if you dont lift the truck the pan sump will hit the engine adapter and the axle not clearing the pick up tube it only needs a couple inches and it will slide in and out easly
