oil filters over stock oil filter??
Any better filters to use in place of stock oil filter.. I may put on the oilguard or amsoil single bypass filter system.. but was wondering about the stock filter.
the oilguard bypass filters are 1/3 the price of the amsoil bypass filters. one reason on using just a single bypass system is space and ofcourse $$$..
Originally Posted by bluebull
Mopar filters are just standard Fleetguard filters rebadged
Originally Posted by wap
How does wix stand up to the fleetguard?
Tony
Its not just about filtration with filters.....
There are other things to consider.
Like: Cummins engines tested only with Fleetguards.
Fleetguards are designed around heavy duty use, not "lets just build a filter to fit it and hope it works".
That makes a big difference to me in my choice.
Who does wix test with again?
I am sure the wix are fine.
Does wix have the Stratopore option? Heavy case option? Increased volume porting?
Or just the "oh yeah that should work" engineering.
Hmm....
Hmm....
I'm a fleetguard fan as well, but I'd give consideration to the new Donaldson Endurance filters.
Donaldson is a world leader in filtration media, and if anyone could build a filter to exceed the performance of the FG units, THEY would be the ones to do it.
Oh, and Donaldson has a *tiny* bit of experience in the heavy truck market, you could say.
Hmm....
Hmm....
and also Mobil 1) or (God forbid) FRAM
. They make a solid quality filter. Price doesn't mean much if you're going to ruin a $6000 engine, but I have been buying the base filter for $4.53 and the heavy dutys will cost $8.17 through Filter1. I am a NUT on oil and filter changes. When I found out how bad Frams are, I threw everyone I had (about a dozen) in the trash. If I thought that a WIX filter and dino oil wouldn't easily give me another 200K on my motor, I would never use either. JMHO
In all liklihood Wix is a re-badged Fleetguard or Donaldson or vice-versa. I bet only one of them actually makes both versions and the other two resell it as their own.
I vote for Fleetguard cause why not use the same company when they offer a good product?
