oil filters over stock oil filter??
Old Dec 7, 2005 | 07:50 AM
  #31
RustyJC's Avatar
Originally Posted by ckennedy
Forgot exactly how to read the beta ratio.
Here ya go:
Beta Ratio - A mathematical expression defining the number of particles of a given size upstream of a filter relative to the number of particles of the same size downstream of the filter. The Beta ratio (ßx) is an indicator of how well a filter controls particulate. It is the ratio of the number of particles (>xµm) entering the filter to the number (>xµm) that pass through. If one out of every two of the particles (>xµm) in the fluid pass through the filter, the filter's Beta ratio at xµm is "2." If only one out of every 200 of the particles (>xµm) pass through the filter, the Beta ratio at xµm is "200." Therefore, filters with a higher Beta ratio provide better particulate control and hence better system protection.
Rusty
Old Dec 7, 2005 | 08:30 AM
  #32
DirtEater's Avatar
Forget the science lessons, lets
Old Dec 7, 2005 | 08:32 AM
  #33
motrapper's Avatar
before i hear one more iam better than you statement does anyone else have any blackstone or other stats from oil analysis i have used amsoil and now mostly wix and all samples come back with less than .3 insolubles now that is real world number not maybe betas etc... please post some other real world numbers please
Old Dec 7, 2005 | 08:46 AM
  #34
RustyJC's Avatar
Please accept my apologies. I'll attempt to refrain from responding to any technical questions in future threads where you might be participating.
Rusty
Old Dec 7, 2005 | 09:22 AM
  #35
ckennedy's Avatar
Rusty
I forgot to take that statement out - as my next post I answered my own ?? about how WIX stated it..
ps: I would love some real number too.. it is just if you go looking for something you have to base you "buy" on something other then just guessing!
I know someone who bought a filter based on the brand and others saying it was good.. turns out it was a station pump filter and had a nominal rating of 15 or 20 mircons.. I was looking for a 8 to 10 micron absolute.. so it did matter to do some basic checking!
Old Dec 7, 2005 | 10:16 AM
  #36
DirtEater's Avatar
Rusty
No harm meant Rusty, it's all good in da hood. Thanks.
Old Dec 7, 2005 | 10:50 AM
  #37
ckennedy's Avatar
allright!
what about me - I went off and looked this stuff up - posted it - and all you all can do is throw used motor oil at each other
Old Dec 7, 2005 | 04:06 PM
  #38
TPilaske's Avatar
That's it, I'm switching to FRAM all around!
Old Dec 7, 2005 | 04:22 PM
  #39
HaulinBut's Avatar
ok
a little data but could not find all data wanted
flleetguard LF16025 98.7% at 27 mircons
.........................60% at 10 microns
Wix 57620XE nominal rating is 14 microns
.................. Beta Ratio: 2/20=14/25
above beta ratio menaing 2/14 50% at 14 mircons
................................. 20/25 95% at 25 microns
plus
baldwin BT7349 Nominal 12 / beta factor 2
.........................absolute 30 / beta factor 75
above means at nominal 12 microns at 50%
..................... absolute 30 mircons 98.7%
So on paper looks like Fleetguard takes the lead by a % !!
ps: ever wanted to cut open a filter - I just cut open a Fleet stratapore.. Don't ask me to do it again
Holy Smokes! If we're gonna get this serious, why are we all not running a bypass filter/oil cleaner? As posted on DTR in the past, the bypass filters supposedly stop everything to the sub-micron level. Even heard claims that they would stop the particles in cigarette smoke.
Old Dec 8, 2005 | 11:59 AM
  #40
TPilaske's Avatar
Just an FYI -- I was looking around on http://www.dodgeparts.com and they have a case of Mopar oil filters for $100.20 for the diesel trucks. I'm assuming these are rebadged fleetguards. Seems like a good price ($8.35/ea.).
Tony
Old Dec 10, 2005 | 10:13 AM
  #41
C Schomer's Avatar
I like the 3894. I think Fleetguard told me 73% @ 10 micron. I bought the Oilguard when they were 1/2 price and got a lifetime supply of filters - all for <$200. Frantz would be my next choice. Dad had them on his 50s trucks and they work great - and cheap! The cost of Ams rules them out, for me! If you want good AND cheap, use the fleetguard bypass base and spin-ons. Craig
Old Dec 11, 2005 | 09:46 PM
  #42
rickkari0304's Avatar
Take it easy on the replies guys??? I have a Fram AirHog in my 06. Are they really that bad?? I looked at it compared to my AFE and it looks like it is higher build quality. If I get enough honest "it sucks" it will be gone tomorrow.
Please let me know.
Old Dec 12, 2005 | 03:33 AM
  #43
PourinDiesel's Avatar
The air hog air filter is foam based, it probably isnt that bad.
Old Dec 12, 2005 | 03:42 AM
  #44
russ300h's Avatar
Fram OIL filters are pretty bad. It is the unnamed poor quality filter Dodge and Cummins warn you about in their manuals. Dodge or Cummins will walk away from you if you have an oil related engine problem and they see the Fram filter (or filter made by Fram like Pennzoil etc.). I think the Tough Guard isn't too bad, but it is pricier than better filters.
That said, I removed a Fram fuel filter from a friend's '96, cut it open and it appeared to be very well made. I can't comment on the Air Hog, I don't know anything about them. In general, anything from Fram that is well made is overpriced.
Filter1 sells the WIX XE's for just over $8 and Scheid Diesel sells the Stratopores for about the same price. Why go anywhere else??
Old Jan 1, 2006 | 09:50 PM
  #45
magicheater's Avatar
filtermania
First thing I did when I got my truck was to change all the filters, except air as was good. I get the wix for 8.89, lists for 17.51 at a parts store I am loyal to. I took a fram off! used a wix fuel filter too. like to participate in the LOCAL ecomomy if possible but if harm is going to be done to my diesel investment would change.
