Oil filter removal/replace procedure ???
Old Jul 9, 2017 | 01:42 PM
Seabiscuit's Avatar
wait
Originally Posted by john40
If you have the option and time, let the truck sit over night. The filter is not hot and it allows the filter to drain slightly. It is not messy when removing from below.
John
That's what I like to do, wait. I use to just waited till it cooled down. Then I would get oil down the filter and run right on down my arm.
For years now I wait a night and change it the next day, and it seems to make a difference. No mess at all, I have always changed from under the truck. Gives me time in the shade, relax, look at everything closely.
It is a easy change. I have been using Chevron Delo 400 LE oil the last couple years. The truck seems to like it ok. No weird noises or noticeable usage.
In the winter I switch to the Delo 5w-40.
Good truck,
Old Jul 10, 2017 | 12:25 PM
john40's Avatar
Good truck,
I forgot to mention that I let the oil drain overnight.
John
Old Jul 10, 2017 | 01:25 PM
Jeff in TD's Avatar
I've always been a believer in the theory that one of the main benefits of an oil change is to remove contaminants like carbon and wear material, so I prefer to drain when the engine is freshly run- with the idea that stuff would be in solution and not settled out in oil passages and various surfaces.
Old Jul 10, 2017 | 03:14 PM
john40's Avatar
I have been doing this for years, for the same reasons you mentioned.
John
Old Jul 20, 2017 | 08:03 AM
dezeldog's Avatar
X three what they said. I use the Fleetgard LF3894 and a strap wrench from under the truck
tacohat
21
Nov 19, 2025 09:03 AM
armourbl
Feb 6, 2014 01:37 PM
BC-01-CTD
Jan 25, 2010 08:01 PM
gator_grabber
Apr 19, 2009 06:34 AM
Eskimo
Jan 25, 2005 06:27 PM
