Injector removal procedure
Old Apr 18, 2009 | 11:45 PM
gator_grabber's Avatar
I'm searching around for an article on removing and replacing 24V injectors. Any leads? Thanks.
Old Apr 19, 2009 | 01:28 AM
pind's Avatar
remove the intake horn and grid heater, detach the lines from the transfer tubes at the head, use a small screwdriver or plastic scraper to pop the transfer tubes slightly out of the head.
then, under the valve cover, undo the injector hold down bolts, which I believe are torqued to 90 inch/lbs. you only have to remove the "front" bolt of each hold down. Then, using one of those bolts threaded into the top of the injector, use a small pry bar to "pop" the injector loose. Lift up and out, replace with new injector, o-rings, and copper washer.
You will feel the new injector " snap " into place, then replace the injector hold down, do not torque yet. Pop the transfer tube back into place, figner tighten the injector line, then torque the hold down to 90 inch lbs. finish tightening the injector line, move on to the next injector.
Always remember to pop the transfer tube out of the head a bit, so as not to wreck it while removing the injector.
Good luck.
Old Apr 19, 2009 | 06:34 AM
Thanks for the info, that's just what I need.
sdseva
Aug 2, 2010 03:48 PM
TxDiesel007
Apr 4, 2006 01:17 PM
kawi600
Jan 26, 2006 10:19 AM
Eskimo
Jan 25, 2005 06:27 PM
