Oh MAN!! My first oil leak!!!
Old Oct 30, 2006 | 03:36 PM
SmokenRam's Avatar
I noticed i got some oil on the back side of my oil pan. Might be rear main or oil pan?? Not sure. Please tell me that the new motors are not like the old 12v when everytime you get one leak fix, another pops up??
Old Oct 30, 2006 | 06:30 PM
crobtex's Avatar
I don't know where your oil filter is, but on mine, if you're not real careful oil will run down and look like an oil leak.
Old Oct 30, 2006 | 07:09 PM
Big P's Avatar
Mine is leaking there too, well actually it shows up on the inspection cover of the tranny. The bolts on my oil pan were loose, but re-torqing them didn't help. It's not from the blow-by tube either. It annoys me too, but not enough to fix it.
Old Oct 30, 2006 | 07:13 PM
Geico266's Avatar
Gentlemen, an oil leak must be of sufficient quantity to actually form a droplet and hit the ground.
What you have is oil seepage, not leakage.
And besides, a CTD does not leak, it marks it territory.
Old Oct 30, 2006 | 07:18 PM
Kemble's Avatar
External oiling system's rock .
Old Oct 30, 2006 | 07:31 PM
boostjunkie1's Avatar
Talking
Thats a good one!
Old Oct 30, 2006 | 07:46 PM
whitebuffalo's Avatar
its just sweating horsepower......
Old Oct 30, 2006 | 08:27 PM
nfsommer's Avatar
check your oil filter, make sure its on tight!
Old Nov 2, 2006 | 01:20 PM
ShaneCTD600's Avatar
I also have noticed this same leak. At first I thought it was from the blow by but while installing my new trans cover I noticed it was on the back of the oil pan between the trans and the engine. Anyone know more please chime in. I am about to bring it in. Cement driveway doesn't like it too much
Old Nov 2, 2006 | 05:07 PM
expressfish's Avatar
keeps the rust at bay.............I have the same prob, not enought to warrant changing the gasket until it drips on the driveway.
Old Nov 2, 2006 | 09:56 PM
wimpy76's Avatar
Took mine in about two weeks ago and they told me what I thought they were going to say blow by out the crankcase. My dealer seems to be pretty good so keep an eye on it and take it in if it gets worse. I dont know about you guys but I am not using any oil.
Old Nov 3, 2006 | 01:29 AM
TexasCTD's Avatar
I think ya'll are worried about nothing. My blow-by tube sprays a little oil on my oil pan and trans housing in the same place you are describing. Mine doesn't leak any on the ground though and the oil level is always full even after 5k miles (my oil change interval).
I just wipe it off the oil pan every once in a while, usually at oil change time.
Old Nov 3, 2006 | 09:49 AM
rammv's Avatar
I had the same thing what I thought was oil film on the tranny cover plate.took it in and they said it was tranny fluid.they had to pull the tranny and replace some seals.will get it back today and see what the paper work says and let you know.
irocpractice
Aug 11, 2011 04:02 PM
Rick 12v CTD
Jan 21, 2011 07:47 PM
Badger555
Jun 5, 2007 10:43 PM
reidry
15
Dec 20, 2005 09:35 PM
Lsufan78
May 24, 2004 12:25 AM
