Is this normal drivetrain wear for a truck with 19k mi?
Old Apr 29, 2007 | 02:38 PM
05 CTD2500's Avatar
I don't really have any experience in the driveline department so could someone help me with this?
Earlier I was trying the hose clamp on the rear driveshaft to try to track down a 70mph+ vibration (clamp didn't change anything btw) and noticed some things.
1. Is the rubber seal failing a sign that something else is going on here and how easy and cheap to replace or just take it to the dealer?
2. Is it normal for the u-joints to leak this much grease? I've shaken everything and can't find any play anywhere.
Any help is appreciated.
THE PICS:
Old Apr 29, 2007 | 06:17 PM
Sprinter17's Avatar
Muted User
Looks right for a truck with about 60-70K on it, not 19K. Check all the rubber mounts, must be a lot of something vibrating, or flexing to tear that seal apart. Could be a leaking seal on the U-Joint, or the joint itself is worn out,therefore causing the grease to fling out because the needles aren't centered anymore.
Old Apr 29, 2007 | 06:31 PM
03 ant a hemi's Avatar
Quality Dodge parts.
Old Apr 29, 2007 | 07:22 PM
Rick D's Avatar
I see your in hampton, pull the shaft and take it to craft machine shop, off of aberdene rd. let them check and repair with a good quality greasable joint and center bearing.
the dealer will fix it but you'll end up with the same crappy non greasable joints.
Rick
Old Apr 29, 2007 | 08:16 PM
05 CTD2500's Avatar
anybody know how much the dust boot costs? been looking at the service manual looks real easy to replace. if its cheap I'll just replace it myself.
I've decided to pull the front driveshaft next for troubleshooting purposes.
Rick, I'm actually in NN, thanks for letting me know of a good shop here. what kind of $$$ you think I'd be looking at for the work?
Old Apr 29, 2007 | 09:01 PM
supersonictoys's Avatar
my 06 has 11k miles and that same boot is cracked in the same way. its not a seal , just a dust boot
Old Apr 29, 2007 | 09:09 PM
05 CTD2500's Avatar
thanks I get it now since I looked at the service manual
so the shaft coming from the rear of the transfer case gets no lube?
Old Apr 30, 2007 | 06:01 PM
Rick D's Avatar
I took in my own parts 3 u joints presision 351's, and a napa carrier bearing
the labor to rebuild was 130.00
They will supply parts also for a decent price.
Rick
Old Apr 30, 2007 | 08:33 PM
05 CTD2500's Avatar
thanks for that info, good to know.
kingofdodge7131
Big Rigs
18
Mar 30, 2011 10:08 PM
05CTDN8
Feb 23, 2011 07:39 PM
FDX
21
Apr 10, 2007 09:47 PM
iwannaram
Dec 4, 2002 10:19 PM
northjeepster
Oct 15, 2002 01:11 PM
