Normal boost on 2006 2500 ?
Old Jan 20, 2008 | 12:05 PM
Big T's Avatar
What is the normal boost? I can only reach 27 on mine.
Old Jan 20, 2008 | 12:19 PM
Equalizer 2's Avatar
Mine is a 04.5 and I hit about 32 and it drops back to about 28 and stays there.
Old Jan 20, 2008 | 01:03 PM
cconrad331's Avatar
Iv hit 33 according to my bullydog outlook highs. That was racing a Ford 6.0 so I was on it harder than usual. Triple dog was set on performance, 100HP or so???
Old Jan 20, 2008 | 02:08 PM
dfer10's Avatar
27 is right around where it should be
Old Jan 20, 2008 | 05:48 PM
BRT's Avatar
BRT
Modded aibox and muff delete would hit 34 then drop right back to 30 and stay as long as I was in it.
Now with the Jr., It'll hit 38 and stay till I let off.
This is with a boost bolt where Diesel Manor says install it.
Old Jan 20, 2008 | 06:01 PM
Bswope's Avatar
I can hit 35-36 stock.
Old Jan 20, 2008 | 06:34 PM
P.J's Avatar
P.J
And stay there?
Mine has only ever spiked above 30, it quickly wastes to 27-28psi.
Old Jan 20, 2008 | 08:29 PM
mizzu's Avatar
Drop $75 and get a Qzilla boost fooler. Mine with Stuper Chip in performance mode will peak at 47 and hold it till you chicken out. whoo hooooo!!!!
Old Jan 21, 2008 | 07:57 PM
Bswope's Avatar
Originally Posted by P.J
And stay there?
It'll hang there for a bit, but then settles around 28 or so!
Old Jan 21, 2008 | 08:12 PM
P.J's Avatar
P.J
Ah, there we are.
I've been thinking about a boost fooler lately, like to run closer to 35 or so when the need arises.
Old Jan 21, 2008 | 10:53 PM
speakle's Avatar
Just got my guages installed yesterday (dieselmanor kit) and was surprised to see that it will only go to about 30psi breifly. I used let off a lot when I had the edge/attitude because it would spike to 40psi very easily, 43 was the highest I ever saw with it.
Old Jan 22, 2008 | 01:44 AM
BENCH's Avatar
My truck would peak 30psi then level off to 27-28psi stock. Installed the Quad Boost Fooler and now peak at 36-37psi and will stay there until I let off. My Dads "stock" (K&N Intake & Cat MIA) '05 will peak 35-36psi and level off to 31-32psi. I bought a 60psi gauge because I thought I would peg a 0-35psi gauge like my Dads '05, then had to buy a Boost Fooler so that it I could use the 35-60psi half of the gauge. It seems like these trucks have a broad stock boost range of 30 to 35psi.
Old Jan 22, 2008 | 08:50 PM
Fast Tommy V's Avatar
Ive read threads similar to this in the past and yea it seems like there is a extremly broad range of boost. Does anyone know why is that? I wanted to say elevation but I havent really seen much coorelation though. FYI my 06 will stay at 40 psi with the juice on level 3
Old Jan 22, 2008 | 11:10 PM
Racing4funn's Avatar
Boost fooler sounds great but is it needed if I run a Bully Dog?
jmccart
14
Sep 17, 2007 08:23 PM
jrussell
17
Sep 17, 2007 06:38 PM
wrangler04
35
Jul 27, 2007 07:08 AM
06bigred
Jan 16, 2007 12:44 PM
DanTana
Mar 6, 2006 05:56 AM
