No start 5.9
Old Dec 14, 2010 | 10:31 AM
mcleandeeres's Avatar
No start 5.9
I havea 5.9 11-2006 and it will not start with out injecting starting fluid in the in take. then it runs 80% lacking power the dealer says it fuel pressure so they cleaned the pressure sensore for 181.00 and called it good. I replace the sensore and no go. if you turn the truck off and try to start it again it will not work. HELP EATHER IS GETTING EXPENCIVE i would like my old truck back
149090 miles
new pumps and inj at 96000
all stock
4 door dually
thanks Mclean
Old Dec 14, 2010 | 10:55 AM
jkitterman's Avatar
Do not use ether with the grid heaters connected! Pull and post any codes you are getting. What fuel pressure are you talking about, low or high side of system.
CoastalDav's Avatar
There are muliple things that can cause this.
1. Is the engine intake heater working ? I assume its cold were your at.
2. Is the engine turning over fast enough ? Starter ? Batteries ?
Sometimes when the batteries are marginal, the hit by the intake heater will knock them down enough so the engine will not spin fast enough. Load test the batteries. Check the grounds on the starting system.
3. Fuel related as you've mentioned, filter good, tank pump, rail pump, injector(s). Any codes ?
If it starts with starting fluid and stays running, and has good power, I would look at the starting items and turnover speed. All starting fluid does make the combustion happen at a much lower temp in the cylinder and lower turning speed.
Using starting fluid is not a good idea.
Dave
Old Dec 14, 2010 | 11:36 AM
No start 5.9
the rail pressure is low 1100 at cranking over when it does start its around 4300 the codes the dealer gave me is fuel dealiver system theres a new pump in tank and filter are changed offten no bio blend i run around one tank per day heater is un hooked and they do work when it does start it takes off and run ok 80% i do not like that the dealer disable the cruise ideal controls its auto now
Old Dec 15, 2010 | 02:52 PM
the codes are po237,po113,po193,po148,po251 i think the pressure check valvue is bad
CoolumConst
Oct 11, 2008 10:00 PM
bfarrell
Nov 30, 2005 03:23 PM
Erik Dlux
24
Dec 8, 2004 07:26 AM
502502
Nov 27, 2004 09:15 PM
eng208
Jul 14, 2004 06:21 PM
