no fuel common rail wont start
Old Mar 13, 2008 | 08:36 PM
kidhulr's Avatar
Angry no fuel common rail wont start
posted on help truck died, changed filter, opened drain, fass working, cracked pressure valve, removed pressure valve. more fuel then started with but not overflowing or spraying. please any ideas other than cp3?
Old Mar 13, 2008 | 08:43 PM
eastmentCTD600's Avatar
when you crank it over do you get any white smoke or smell unburnt diesel in the exhaust pipe?
Any codes? To check codes, cycle the ignition key as follows: on-off-on-off-on (and leave it on the third time). The odometer will display error codes if any are present.
Hope this helps.
Old Mar 13, 2008 | 08:50 PM
kidhulr's Avatar
not checked the pipe codes showing are p0628 and p2509 but i believe they are old. when i went fass was unable to get power from stock pump power line.
Old Mar 13, 2008 | 09:05 PM
Well, "P2509 - ECM/PCM Power Input Signal Intermittent" That would certainly cause a problem. Are your batteries in good shape? You might want to check your wiring harness to the ECM (mounted to the engine on the drivers side) to see if there are any loose, missing or chewed-up wires.
Old Mar 14, 2008 | 06:55 PM
kidhulr's Avatar
just charged batteries two days ago, checked wires and conectors tonight and everything looks ok.
Old Mar 18, 2008 | 08:44 PM
kidhulr's Avatar
any other ideas?
Old Mar 19, 2008 | 12:03 PM
grandblanc's Avatar
can you jump it or doesn't it start at all? when my cp3 went, i could start it, but i ran rough for about 10sec. then smoothed out. my cp3 was bleeding off pressure and allowing air to leak into they fuel system.
Old Mar 19, 2008 | 12:25 PM
staarma's Avatar
It bothers me that you couldn't get power from your stock lift pump harness. Also, the code 2509 may have something to do with that issue. It sounds as though the driver for that signal could be faulty in the ECM which is what could be causing it to not start. Also, why did you have to charge the batteries? I hate to say it but if you had to charge the batteries then they are probably no good or not good enough. I would try to clear those codes and see if they come back up. They may be related to your original lift pump going out. If they don't come back up then you may be buying a couple of batteries.
Old Apr 17, 2008 | 08:01 PM
kidhulr's Avatar
NEW UPDATE!
new batteries did nothing. Either got it to fire up. would not push mure than 1500 rpm to the floor. very little response from the throtle. now showing codes 0628,2509,2146,2149. would idle forever with no problems. 30 mph at idle in 4th gear got it to the dealership. 99.9% sure the problem is in the ECM. any other ideas?
Old Apr 18, 2008 | 09:18 AM
staarma's Avatar
628 is the lift pump voltage. So your harness or signal is messed up. 2146 and 49 are injector banks voltage. So, your harness or signal is messed up. The 2146 and 49 could be the wires shorting to the rocker cover. Some guys have experienced that. If none of that checks out then it could be your ECM. Hopefully someone with knowledge could jump in here.
Old Apr 18, 2008 | 12:37 PM
rich's Avatar
i've had it short out under the valve cover and it seems like the same thing if i remember right been awhile since then
crewcabxlt
Nov 9, 2009 12:51 PM
coope3
May 29, 2008 06:34 PM
gotsmoke6
Jul 17, 2007 06:31 PM
Jmac
Apr 22, 2007 04:45 PM
