Newbie,, needs advice
Old Jan 6, 2009 | 05:31 PM
Diamond266's Avatar
Hey Guys I'm new to the forum,But real quick,My name is Santo,I'm from N.Y. and running an 04 Ram with a 5.9 all stock, I have around 75,000 miles and a check engine light came on so I did a check and iit came up with P0628,Fuel Pump Relay Control Circuit Low Voltage ,at first it was just the light but driving home yesterday it stalled twice ,both times it started back up with lack of power when stepping on the pedal. OK my ? is,,, do I need a new lift pump, a relay, what else should I check, can I add one of those after-market pump just leave the other one on there ,, do the after market connect to the wiring that is there ,,, I'm lost and need help ... Thanks
Old Jan 6, 2009 | 07:20 PM
turbo hoss's Avatar
Red face
It does sound like a lift pump. A set of gauges would tell you for sure. I installed a FASS 95 when my lift pump went south. Good kit not to bad of a install. Comes with all the wiring good instructions, and yes you will have to remove the stock pump it should be mounted on thr fuel filter housing. Some people prefer outher brands but the FASS has not let me down yet. What part of NY ya from? I grew up just south of Buffalo
Old Jan 6, 2009 | 08:07 PM
Diamond266's Avatar
Thank You ,,, I'm a long ride from Buffalo ,,I'm in long Island,,, I didn't look into the Fass yet,, but I will check it out now ... Sandy
Old Jan 7, 2009 | 03:33 AM
05blkdlly's Avatar
I installed a Holley blue fuel pump and a Holley fuel filter under the cab in the frame . Easy to do and works great , also not too much money . I also use these pumps on all my race cars , they are very reliable too . just another idea to look into.
Old Jan 7, 2009 | 05:00 AM
megacabdad's Avatar
Welcome to the Diesel Truck Resource!
Check with your dealer first, as if it is a lift pump, it may be covered under warranty.
Old Jan 7, 2009 | 06:53 AM
98whitelightnin's Avatar
The only problem with a dealer replacing it under warranty is they will put it in the tank instead of the block. The intank pump is good but if it ever goes south its more of a pain to replace.
Old Jan 7, 2009 | 04:25 PM
Diamond266's Avatar
Thanks Guys ,,,I was able to find the OEM @ Geno's Garage 180.00 I should have it tomorrow ,,,, Hopefully that will do the trick ,,, I went under the truck and gave the old pump a rap and it started right up ,,, So that should be the answer,,,I hope when I replace it the 0628 goes away,,, I will update tomorrow ,,,,,,,,,,,,, Sandy
Old Jan 8, 2009 | 06:11 PM
Diamond266's Avatar
Ok Transfer Pump is in ,,, took about a half hour,,,, it did the trick,,,, truck is up and running ,,,, thanks guys
Old Jan 8, 2009 | 08:13 PM
megacabdad's Avatar
Glad to hear it...
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
Hasselholf
Sep 22, 2006 07:17 PM
roadie00
Apr 11, 2004 11:47 AM
maarten
Apr 30, 2003 09:42 PM
atc250r
Dec 6, 2002 07:14 PM
