New G-56?????
Old Jul 15, 2007 | 12:14 AM
Roperteacher's Avatar
New G-56?????
I test drove a 6.7 litre before I bought my new 5.9 07. The manual tranny felt so much better than my G-56 in my 06... Salesman said they had changed the gearing a bit in response to customer complaints of the G-56 being to low geared.
After driving my new 5.9 all week with the G-56 All is well and this trans seems to be higher geared as well. When did the switch happen???? FOr all 07 models???
Old Jul 15, 2007 | 12:21 AM
DiEseLjunKy's Avatar
There's been a few threads about it. Basically the 2007.5 trucks with 6.7L g56 trans have a higher .76 ratio for 6th gear while the 2006 and 2007 trucks with 5.9L g56 have a lower .79 ratio for 6th gear.
Old Jul 15, 2007 | 12:34 AM
53 willys's Avatar
wounder if a guy could Change just the last gears between the two??? I bet you could...that might be cheaper then a set of gears front and rear too???
anybody know if and where to buy G56 parts???
Cool thanks! Must be my imagination then!! LOLOLOL My 07 5.9 sure feels a lot better than my 06 did.... Maybe that was another problem I never was aware of!! LOL Thanksfor the input./.
Old Jul 15, 2007 | 01:04 AM
mrblond's Avatar
whats your RPM's at 70mph? I read the new G56 would be about 2200 rpm give or take 50.
I would like to see a poll on speed RPM for the new G56?
Old Jul 15, 2007 | 01:19 AM
DodgeCowboy's Avatar
DTR's Cow Boss
Why does the 07 5.9 6spd feel really sloppy compaired to my 6spd in my 02? the ranch i ride for has a 07 5.9 with the 6spd and the clutch just seems weird like its all at the top and "clunky" were as my 02 its about the middle and smooth. is it just cause i drive the 02 more?
Old Jul 15, 2007 | 05:00 AM
My clutch in the 07 is real soft thats for sure, but mine shifts smooth as glass. Not once ounce of 'Clunk" to it!! I also have a 96 5 speed and an 02 6 speed. They all feela little different but they are all smooth. Everyone who drives my new truck says they are scared to break the clutch pedal it is so light and smooth.. LOLOLOL
I do believe at 7o I am turning around 2200, I think somehow I got one of the new G-56's.. WIll test it tomorrow, it is DEFINATELY higher geared than the 06 was!!
Say, do you REALLY need to keep it under 50 MPH the first 500 miles you TOW??? IS this for the rear gears??? I puleed 200 miles tonight and kept it as close to 60 as possible to avoid being run over!
grishfish
113
Mar 3, 2013 10:53 PM
OOPS
Aug 28, 2004 07:15 PM
powerwagon440
Apr 19, 2003 07:19 AM
midwestdually
Mar 21, 2003 09:06 AM
akchameleon
Mar 19, 2003 12:39 AM
