New Front Axle Assembly?
Old May 28, 2008 | 04:59 PM
hkmp5sd's Avatar
I had some noise coming from my front end and found that it was a bad U-Joint, also had unusual wear on front tires and drove like crap. I bought the truck totaled with only 1,200 miles. I knew what I was getting into. Took it to a local frame and alignment shop and they said the front axle tube were bent pretty bad. Any ways I purchased an entire front axle assembly and am going to be installing it this weekend. Need some advise on parts that should be changed out while I have it sitting in my shop? U-Joint, bearing, seals, ETC... The new (new to me) front axle assembly has 70,000 miles and the truck only has 23,000 miles.
Thanks
Old May 29, 2008 | 09:44 AM
woodzy's Avatar
U might as well do the u-joints while it is apart... careful on the bearing assembly, it's pretty spendy if you damage it. Ball joints may be shot as well??
Old May 29, 2008 | 02:58 PM
hkmp5sd's Avatar
Thanks. Any special U-Joints or ball joints i should get?
Old May 30, 2008 | 07:29 PM
2006Mega's Avatar
time for the dyna trac kit, eliminate the unit bearings at the same time.
Old Jun 1, 2008 | 11:25 PM
Beat Ram's Avatar
WHat is a dynatrac kit?
What is the dyna track kit? I have a 2003 that has 145000 miles and am looking at worn ball joints and tie rods.
Old Jun 2, 2008 | 08:05 AM
2006Mega's Avatar
http://www.dynatrac.com/products_freespin_dodge.html
the dynatrac kit replaces the unit bearings with standard wheel bearings. it does nothing for the ball joints or tie rod ends.
Old Jun 3, 2008 | 01:02 AM
skchevota's Avatar
My ball joints and tie rods were shot at 35k
I would not use the factory crap.
Old Jun 3, 2008 | 06:40 AM
donhov's Avatar
Although the tubes are bent on you original axles can you use your newer axle to rebuild the older one. Not the ball joints but how about the axles and u-joints at least. That would give you the newer axle parts to match your existing truck without all the expense. Yeah, I know they are not 100k items but might this not be a partial solution to fix what is wrong, bent tubes.....??????
bowhunter96
May 4, 2012 06:25 AM
CLS LLC
Aug 27, 2011 08:15 PM
rustydeeretech
17
May 21, 2011 03:05 PM
jdeereboy
Dec 18, 2004 06:01 PM
rich
May 9, 2003 09:33 PM
