Wrong front axle bearing assembly?
Old Dec 18, 2004 | 02:57 PM
jdeereboy's Avatar
Question Wrong front axle bearing assembly?
I am installing a new bearing hub assembly on the RH front axle. The new bearing (Timken SP580100) has a larger pilot diameter on the hub which makes it not fit into the dually front wheel spacer. The diameter is about a 1/4" larger than the original. Has anyone else had this problem?
The bearing came in a Timken box with the correct part number clearly on it.
Old Dec 18, 2004 | 03:21 PM
duner's Avatar
if the number on the old bearing itself matches the number on the new bearing itself then that would be the strangest thing i've seen in a while. wouldn't know where to send you if that's the case. good luck
Old Dec 18, 2004 | 05:44 PM
jdeereboy's Avatar
Looks like I ordered the wrong bearing. The dual rear wheel trucks require a different bearing. I need part SP5801002, not SP580100. Oh well, I wasted another day messing around.
Old Dec 18, 2004 | 06:01 PM
duner's Avatar
don't sweat it, it's only time
Prodart440
May 17, 2012 01:31 PM
matthopp
Apr 15, 2009 11:13 PM
hkmp5sd
Jun 3, 2008 06:40 AM
Hawkeye
Apr 29, 2008 10:24 AM
rich
May 9, 2003 09:33 PM
