Need some help Please!!
Old Aug 25, 2008 | 06:08 PM
Butzdiesel's Avatar
Driving home from Terra Haute yesterday i noticed my engine starting to chatter loud all of a sudden. Let off the accelerator and it quits, when you accelerate it goes away and then once you hold it at a steady rpm thats when its really noticable! Turned off my powermax- didnt help, unplugged my powermax with the bypass conn.- didnt help either. Whats the deal?
Old Aug 25, 2008 | 08:17 PM
CTDinMT's Avatar
Have you checked for codes? Sounds like your in limp-mode. Whenever I get a P0192 code, my engine knocks like crazy and barely idles. Do you have a code reader? If not, one of you local auto parts places should have a loaner. Once you clear the code, it should be back to normal. My Quad Xzillaraider will throw a P0192 every now and then. I now keep a code reader in the truck, just for that. You can key on, key off three times as well if you just want to check for any codes.
Old Aug 25, 2008 | 10:13 PM
Townsend600's Avatar
There aren't any check engine lights. We'll check codes tom. afternoon. Truck runs fine just sounds horrible.
Old Aug 27, 2008 | 07:04 AM
I don't know what's going on but when you floorboard it even in neutral it sounds like a a vp 24v. Like injector rattle from cylinder 3 or 4. Lots of clatter. any suggestions.
Old Sep 4, 2008 | 12:55 AM
BigIron70's Avatar
Cummins Guru
Sounds like Fuel Control actuator went bad. Part # 05183245AA
Old Sep 5, 2008 | 12:07 AM
kawiram's Avatar
Do TSTs read rail Pressure? I damaged the power wire on my Qzilla rail pressure guage and had very similar symptoms.
Mini_Donkeys
Apr 19, 2007 12:21 PM
SuperiorRam
Mar 15, 2007 03:10 AM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
