Need opionion on knocking noise, video w/valve cover off
Old Nov 11, 2008 | 12:11 AM
  #31
thumper549's Avatar
Like I said all you had to do was count If the noise is 1/2 the speed of crank and parts = valve train, Same speed as crank and parts...has to be...crank and parts .
I am not clear on one pt here, are you useing the old block ?
Old Nov 11, 2008 | 01:21 AM
  #32
cLAYH's Avatar
Originally Posted by thumper549
Did that fail under load ?? looks like heat build ( soaked ) to sag in the middle like that
See the first post for the history. I'm guessing the PO got it REALLY hot. Funny though as the piston looked ok when I had the head off the first time.
Old Nov 11, 2008 | 01:27 AM
  #33
cLAYH's Avatar
No old block has damage on teh cylinder walls.
Picked up a used SO motor, totally complete. Had to reuse my HO wiring harness, there were a few small differences, my AC comp(the one on it had a siezed clutch), PS pump(the donor one got wacked somewere along the way), and the oil pan pickup tube(the donor truck was wrecked when it went of the end of a road and into an embankment, diff came up into pan).
Engine is assembled with a new SB 450HP clutch, new rear main seal and oil pan gasket. Sitting on a hook waiting to go in.....
Old Nov 11, 2008 | 09:22 AM
  #34
thumper549's Avatar
OK then I will not be a PIA..If you were going to put the old back in , I would think the piston oil cooling jet should be checked....would be good to know when the autopsy comes up
freds89
Jun 17, 2009 09:46 PM
sallyman1
34
Apr 26, 2009 06:29 AM
displacedtexan
17
Dec 7, 2006 09:13 PM
wagonhauler
13
Apr 19, 2005 10:47 AM
TroyH
Sep 15, 2004 10:17 PM
