Need opionion on knocking noise, video w/valve cover off
The Cummins injector test fitting is at the bottom of this page.
http://hoeslidiesel.com/store/page13.html
MikeyB
MikeyB
But if you can disconnect one injector at a time I would do that and save the 60 dollars. Just do one by one and see how the engine reacts. You will see all sorts of DTC's when you do and for evey injector you shut down, there should be a 75-80 rpm drop.
Pulled head last night, #6 piston was scuffing the wall, the top of it had started to disitergrate and pieces had broken off which then beat up the BRAND NEW HEAD!!!
I picked up a low milage SO engine just now, hope to have the truck running by Tuesday evening.
I'll see what I can do..........
well at least you found the problem.
don't want to blow my own horn but my gut just told me it was a piston problem. I'm sure you know this but make sure you look at the tip of number six injector to make sure it's not all beat up too. Most likely is. Check the turbo aslo those pieces went some were. Hope you get it running soon.
