Need help!! Turbo surge under load!
04 CUMMINS when its under a load like pulling my fifth wheel it starts Turbo surge so bad I have to downshift into tow haul or just pull over!!!! The truck is totally stock exert for Smarty ssr 5inch ex and cold air. No codes and still does it with programer off.
Is it like someone is pressing on the pedal even though you aren't?
I get that sometimes with my '03, as soon as I let of the pedal it goes away. Been fighting with it for 3 years now.
Do you have boost, low side & high side fuel pressure gauges?
These would help to determine what is exactly surging.
For example, my truck surges a bit when empty on the highway on cruise control.
I can see the rail pressure going up & down a bit on the gauge which of course causes the boost to vary slightly.
It turns out this is completely normal with a modified FCA in the CP3.
I have the Arson kit in my CP3.
Have you checked out your turbo? Shaft spins easy, end play?
How about the basic stuff too? Air filter clean? Recent fuel filters?
garyandbarb
Aug 15, 2009 03:54 AM
HappyGA
Oct 31, 2008 07:50 AM
Snoxracer
Feb 29, 2008 11:57 PM
Dodgezilla
Feb 13, 2004 03:40 PM
