Need code help
Old Jun 13, 2006 | 10:12 PM
horsepoor68's Avatar
Need code help
I checked to see if I had any codes today and this came up P0514 Batery Temp. The truck had been doing good with new engine. So just wondering what this code ment. The only problem i have noticed well wife noticed are the vents on her side dont blow as cold as driver side and sunday they would blow warm at times.
Old Jun 13, 2006 | 10:28 PM
bekim's Avatar
It's common on '04 up and is a code that comes and goes often depending on the air temp outside. Reset it and carry on.
Old Jun 14, 2006 | 10:02 AM
Spooler's Avatar
Different temps coming out the vents is either a fin temp sensor location or your A/C system is low on refrigerant. Probably low on refrig. Sometimes can happen when replacing engine. Moving compressor out of the way may cause a small leak. Take it back and have the A/C checked.
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
