2005 with P341 code
Old Jun 14, 2006 | 09:30 AM
Don Anderson's Avatar
2005 with P341 code
I have a friend with a 2005 1 ton. It is a 6 speed with the HO engine. He has the check engine light on and the code showing is P341. Can anyone tell me what the code is? Thanks.
Old Jun 14, 2006 | 10:26 AM
Artie04's Avatar
Heres what 04 Power Train Diag Manual says about error:
Symptom:
P0341-CAMSHAFT POSITION (CMP) SENSOR SIGNAL
When Monitored and Set Condition:
When Monitored: While the engine is running.
Set Condition: The ECM no longer detects a signal from the Engine Position Sensor.
POSSIBLE CAUSES:
INJECTOR DTC’S PRESENT
OTHER DTC’S
CAMSHAFT SENSOR
(K53) SIGNAL CIRCUIT OPEN
(K72E) 5-VOLT SUPPLY CIRCUIT OPEN
(K55) RETURN CIRCUIT OPEN
(K53) SIGNAL CIRCUIT SHORTED TO GROUND
(K53) SIGNAL CIRCUIT SHORTED TO (K72E) 5-VOLT SUPPLY CIRCUIT
(K53) SIGNAL CIRCUIT SHORTED TO (K55) RETURN CIRCUIT
(K53) SIGNAL CIRCUIT SHORT TO VOLTAGE
ECM
INTERMITTENT CONDITION
Old Jun 14, 2006 | 03:16 PM
Thanks
Thanks for the quick reply.
DADDY'S DIESEL
Dec 4, 2018 09:08 AM
BCarmicle
Sep 14, 2005 07:27 PM
shortround
Jun 25, 2005 10:28 AM
jbeauv
Jun 24, 2005 10:44 PM
shortround
Feb 5, 2005 08:40 AM
