My jaw hit the ground today when I opened the hood
Old Jul 12, 2006 | 07:34 PM
doorguy's Avatar
I opened the hood today and found the air cleaner off. I have an airaid system and it looks like someone tried to rip it off rubber is torn by the clamp and it was just laying in the bottom of the box. I just cleaned it a couple of weeks ago and I know the clamp was tight, I had to loosen the clamp to put it back on, it just doesnt make sense how it came off. Enough babbling what I am worried about is how much dust can the engine injest without damage, you could see your finger marks on the edge of the tube in the dust, was not very thick but there was some there. I was just under the hood a few days ago and everything was fine. I dont think it was off long.
Old Jul 12, 2006 | 07:56 PM
ThirdTry's Avatar
If your airraid filter is anything like the one I had on my old Powerstroke it probably filters just as well laying in the bottom of the airbox as it does attached!
Old Jul 12, 2006 | 08:49 PM
Tiny's Avatar
How did they get under the hood?
Old Jul 12, 2006 | 10:44 PM
JBurn's Avatar
The same thing happened to me. You have to make sure that the filter is over the little burr/notch and clamped over it to hold the filter in place.
Old Jul 14, 2006 | 04:54 PM
SkyHarborCowboy's Avatar
That aint nothin!!!!!!!!!!!!!!!!!!!!!!! Try opening your hood and having a jack rabbit jump through the hole in between your head and right arm that is lifting up the hood!!!!!!!!!
That is scary!
Joe
Old Jul 14, 2006 | 05:02 PM
Pack Mule's Avatar
That is scary!
Joe
no that is hilarious. i would have wet myself from laughing so hard if i'd have seen that.
Old Jul 15, 2006 | 11:00 PM
6 2 Carl's Avatar
Change the oil ASAP. and take a oil sample. You will probally want to take the intake apart as well and clean it out as well.
Old Jul 17, 2006 | 01:54 PM
SOhappy's Avatar
That is scary!
Joe
I guess that would be one advantage to a DurtyMAX or the PosD ...no room under the hood for the Jack Rabbit!
Old Jul 18, 2006 | 11:01 PM
kansaskingairpi's Avatar
I bought my truck from an airforce fighter jock from alaska.....(23k on it at the time)
He drove it from alaska to kansas, and when I was checking out everything under the hood, I found that the air filter had 1/2inch (yes 1/2 inch) of crud built up on the bottom of it....
The engine was still running fine, and the funny thing is, the indicator wasnt even indicating that the filter needed to be changed....
I have never ever ever EVER seen a filter that dirty.....
Old Jul 19, 2006 | 01:06 PM
slowwheelin's Avatar
What do you expect from a fighter jock, they're the reason why us jet mechanics are gainfully employed!!
Lockman
Mar 15, 2010 06:56 PM
NotEnufGarage
Jul 17, 2008 11:11 AM
Billm2004
38
May 15, 2008 06:24 PM
Beeram305
Dec 7, 2006 01:18 PM
