mega cab u joint
Old Oct 15, 2009 | 11:18 PM
SNOWJUNKIE's Avatar
mega cab u joint
went to napa today to get a u joint for my 06 mega cab and they said that they can get one for the manual tranny, but the auto in the mega cab is a dealer only joint. I'm needing the rear most u joint just off of the rear diff. I have read on here that the spicer sealed bearings are the way to go, can I get them and anyone know a part #? thanks
Old Oct 16, 2009 | 10:04 AM
BigDiesels's Avatar
x2. I need that u-joint (again) too. THe first time was replaced by dealer under warranty. I'll check tonight and post if I have any luck.
Old Oct 16, 2009 | 10:30 AM
Grit Dog's Avatar
Can't imagine why the ujoints anywhere on the truck would be different between the auto and manual trans????
Old Oct 16, 2009 | 11:05 AM
klx650a2's Avatar
I had to replace my rear u-joint as well. Not a mega cab, but dealer only item and guess what... not greasable...
Old Oct 16, 2009 | 12:20 PM
Lost Lake's Avatar
Manuals have a bigger u-joint to handle the stress of the clutch. I have replaced the rear two, got mine from Napa, no problem.
Old Oct 17, 2009 | 02:49 PM
BigDiesels's Avatar
Picked one up last night. I haven't actually put it in or compared yet, but he said it was for automatic trans. AC Delco p/n 45U0306 and I think he said Precision 330. He said precision and AC Delco are the same manufacturer. It's greaseable, at least.
Old Oct 17, 2009 | 02:56 PM
NickBeek's Avatar
I found the P/N for the rear shaft in my truck at Rock Auto dot com. It specified Precision brand, I can't recall the P/ N right now. Anyway I needed them faster so I went to Orielly auto parts locally and they had the joints I needed. BTW, I got Orielly to price match too.
Old Oct 17, 2009 | 04:25 PM
pwknapp's Avatar
Just put the rear rear u-joint in my auto mega alst night. If you get the NAPA one make sure it is the 330A. The "A" has thinner clips, the plain 330 clips are to thick so seat the joint properly. Also the shoulder on the NAPA joint is much larger and had to buff it with a die grinder to get the joint to fit in the final yoke. Of course 3 cups dropped bearings during assembly also. What an afternoon!
Old Oct 18, 2009 | 10:54 AM
NickBeek's Avatar
Yeah, I battled with dropping needles too (on all three joints). It was amateur day at my house for sure, but perseverance paid off and I got er done.
Old Oct 18, 2009 | 12:46 PM
blitz_81's Avatar
just changed the rear 2 ujoints. it is a pain. got them at oreilly's. gave me the wrong part the first time. 351a for a 6spd. ended up having to buy 3 of them after i broke one about 10 oclock last night.
Old Oct 18, 2009 | 05:24 PM
pwknapp's Avatar
Make sure to tighten the hanger bearing bolts. I had a brain fart and did'nt and yes the drive shaft came out. What a day.
dockrocker
39
Apr 24, 2011 09:43 PM
jimbo486
13
Nov 5, 2009 09:17 AM
jrussell
May 8, 2007 09:24 PM
4x4dually
May 11, 2006 10:46 AM
Holsteinman
Nov 3, 2005 08:12 AM
