washed truck now runs like crapola
Old Dec 16, 2008 | 07:02 PM
modifiedzx10r's Avatar
Unhappy washed truck now runs like crapola
Like the title says I was at the fire station last night and power washed my truck which I normally don't do, and when I went to start it this morning it has run nothing but crappy. Its throwing the P0192 code. My friends that have more knowledge in diesel's said it was my CP3 and they say my lift pump is working correctly, I also have a new fuel filter in it as well. I am hoping that its not this. The truck ran great with no problems untill my attempt to clean it. BTW my truck has 50k on it and its an 06 auto. Any advice would be great and deeply appreciated.
Thanks.
Nick
Old Dec 16, 2008 | 07:37 PM
Ram Daddy's Avatar
Did you powerwash the engine compartment?
Old Dec 16, 2008 | 07:39 PM
MikeyB's Avatar
Check the rail pressure sensor connectors that the Quad box is plugged into. Could be water in it from pressure washing. Add dielectric grease to the connectors.
MikeyB
Old Dec 16, 2008 | 08:13 PM
I did power wash it and the hood was not fully closed, so it got in the eninge compartment pretty good.
Old Dec 16, 2008 | 08:25 PM
rip 112's Avatar
Have you unplugged the Quad to see if it would still run crappy? Clear the codes?
Old Dec 17, 2008 | 08:04 AM
Coolride's Avatar
I cringe every time I mist my engine down, my buddy lost his whole car in an electrical fire after having his engine clean, thankfully the detail shop paid for it.
Old Dec 17, 2008 | 08:29 AM
93-331-29psi's Avatar
I spray the engine down, with simple green, after every oil change then power wash the soap away. Never a single issue, knock on wood.
Old Dec 17, 2008 | 08:59 AM
snoyes's Avatar
Too many things in the engine compartment that don't react well with high pressure water. Did it run crappy immediately after you washed it, or after you let it sit overnight and dry out? If you haven't already you need to let it dry out completely and see if it gets better. My guess would also be water affecting a connection....
Old Dec 17, 2008 | 10:58 AM
cincydiesel's Avatar
Did the air filter get wet?
Old Dec 17, 2008 | 01:07 PM
Air filter did not get wet, and I washed it at midnight and left the station to go home at 6am and it started immediately acting crappy.
Old Dec 17, 2008 | 05:50 PM
So today I took apart all of the connections cleaned them and put di-electic grease on all of them and checked the codes now im getting P0193 as well as the P0192 that I was getting so my question is, is it safe to drive to the dealer to have them fix it.
Old Dec 18, 2008 | 12:11 AM
BigIron70's Avatar
Cummins Guru
P0193-FUEL PRESSURE SENSOR VOLTAGE TOO HIGH
P0192-FUEL PRESSURE SENSOR VOLTAGE TOO LOW
Could be water in the sensor connector on the rail. The fuel pressure sensor is mounted vertically near the top/center of the fuel rail. #1 in picture.
Old Dec 18, 2008 | 12:27 PM
buldaawg's Avatar
I had to change my fuel rail pressure sensor for the Exact same thing..Do not change the MAP sensor. Now for the bad part...I couldnt find a fuel rail PS for under 600.00... I think someone here found one at a German parts place on line...
look under my name for the complete post on this matter in search..
Old Dec 18, 2008 | 03:40 PM
Well I got sick of screwing with it in the driveway, and had it towed away to the shop. Hopefully the extended warranty I bought covers it. Thanks for all your help in this matter.
Nick
Old Dec 18, 2008 | 10:39 PM
CRXsi's Avatar
Guaranteed that the rail pressure sensor connector from the quad has missing insulators and/or two wires going through one grommet which can cause water to get into sensor connector, once there is can seep into the sensor and destroy it. Happened to my friends truck...he was able to get a new sensor from Cummins for under $100...
