Max Brake 1997 to 06 Question
Old Nov 13, 2016 | 06:13 PM
Outrider's Avatar
I have a 1997 Dodge with Max Brake on it an would like to put it the 06. Did the brake lines change between the years? If so can it be done. What will I need to do the swap.
Old Nov 17, 2016 | 09:05 AM
StealthDiesel's Avatar
The discontinued MaxBrake and Brakesmart units are the best brake controllers ever made.
I have had a Brakesmart on my 2004.5 truck for over 8 years.
Keeping your Maxbrake from your old truck is well worth it.
I don't know if the brake line T-fitting from your old truck will work on your 2006 truck. You should remove that fitting and keep it regardless.
Where would one even find such a T-fitting?
Old Nov 17, 2016 | 01:10 PM
Outrider's Avatar
Thats the problem is what T do I need. The truck its on is a 97 2500 2WD an would like it on the 06 3500 4WD. We now use the bed only on the 97 the 3500 is now our trailer hauler.
Dually Driver
13
Nov 13, 2007 09:10 PM
MBman
21
Jun 16, 2006 08:46 PM
belfert
Sep 9, 2004 03:23 PM
fishin fever
Feb 22, 2004 08:32 PM
Zino
Aug 15, 2003 10:14 PM
