1997 4WD ABS/Brake light
Old Jun 6, 2006 | 09:25 PM
MBman's Avatar
ABS and Brake light on, brakes working fine
done so far
1) connections cleaned
2) wire s traced, no shorts
3) fuses OK
4) reset computer
5) replaced ABS sensor on differential housing
STILL ON
What else can I check, any electrical tests I can do
what kind of reading should I get out of rear sensor, continuity or open??
Anything else I can check, this isdriving me crazy
Old Jun 7, 2006 | 11:28 AM
Partsman's Avatar
On my 98 the brake lights worked but same problem as yours. Turned out to be the stoplight switch.
Old Jun 7, 2006 | 01:59 PM
MBman's Avatar
thanks
way to test it before buying new one??
Old Jun 7, 2006 | 02:59 PM
mrwaters's Avatar
Wow I am going through this right now also. I just got off the phone the the Dealer they want $41 for the sensor that goes in the diff.
I took my sesor out and cleaned it, that worked for about 20 miles.
The only diffenence i have is my steedometer is not working below 25 and it is jumping around. I am going to pick up an new sensor tomorrow and change it out.
Gook luck I will be watching this to see what comes about.
Mike
Old Jun 7, 2006 | 03:13 PM
billv45's Avatar
Have you checked for vacuum leaks? My '96 (and I think your '97) have vacuum assisted brakes and insufficient vacuum will turn on those lights. Shut your engine down, count to 10 and disconnect a vacuum line. You should hear the whooossshh of air filling up the vacuum. If not you have a leak. A couple of the connectors on that four-way union next to my master cylinder were too small and would intermittantly leak and turn on my lights.
Old Jun 7, 2006 | 04:09 PM
MBman's Avatar
Thanks,
no I did not check for vacuum , but will
my spedo works fine
I got word from the guy that helped me put in the rear sensor that he had to "pound out " the old one because it was stuck, which means he chiseld it out, I wonder now if he did not bung something up when he did that. He tells me that it just sits in the opening and no damage was done
Old Jun 8, 2006 | 08:40 AM
plow's Avatar
hydraboost on the 97's.
Old Jun 8, 2006 | 09:50 AM
infidel's Avatar
Originally Posted by MBman
thanks
Easier to just buy a new one, about $11 from most autoparts.
Be careful not to bend any pins installing it as it's difficult to see the pins.
Old Jun 8, 2006 | 04:44 PM
MBman's Avatar
what do you mean by this?
Old Jun 8, 2006 | 06:38 PM
infidel's Avatar
Since you have hydro assisted brakes rather than vacuum a vacuum leak won't make your brake lights come on.
Old Jun 8, 2006 | 08:13 PM
MBman's Avatar
so with that info I am leaning more to the brake light switch , for 12-15 bucks , probably worth a try
Thanks again
Old Jun 9, 2006 | 08:56 AM
boughtadodge's Avatar
Check the fuses in the panel on the dash if it is burnt the lights come on.
Old Jun 10, 2006 | 07:28 AM
MBman's Avatar
fuses OK thanks
Old Jun 11, 2006 | 11:00 AM
pittom's Avatar
i had the same problem,a ground wire smoked coming off the master cylinder.my box that controls it smoker so i went to old school breaks no more RWL and also help stoped me truck from shaking under hard breaking.
tom
Old Jun 11, 2006 | 12:09 PM
torquefan's Avatar
Trouble codes can be pulled from the RWAL system, but they changed it in 96 or 97. I don't think you can ground a wire and count flashes anymore, but I don't remember.
