1997 4WD ABS/Brake light
Old Jun 13, 2006 | 11:37 AM
MBman's Avatar
I tried, it did not work, (flashes)
putting brake switch on tonight, will let you all know the results
Old Jun 15, 2006 | 01:23 PM
MBman's Avatar
well put in the brake switch - no help , have the same problem.
does this thing (97) have front wheel ABS sensors, if so where?
Old Jun 15, 2006 | 07:41 PM
Dinner's Avatar
I don't mean to steal this thread, but i have the same lights on, was just out tonight cleaning the sensor on the rear axle, following the wires and no shorts. Im just wondering how you reset the RWAL on a 99 3500? And where to find this RWAL?
Old Jun 15, 2006 | 09:21 PM
MBman's Avatar
OK what does RWAL stand for and do I need to reset it on mine the 97 4WD
Old Jun 16, 2006 | 11:01 AM
Partsman's Avatar
RWAL=Rear Wheel Anti-lock
Only reset to my knowlege is unhook the battries for 15-30 minutes.
Old Jun 16, 2006 | 06:39 PM
infidel's Avatar
Don't know if a '97 is the same but on my '95 I pulled the ABS breaker to see how it worked without anti-locks. Dash lights came on and continued to stay on even after the breaker was replaced less than a half hour later. Disconnecting the batteries didn't help. Later I found in the factory service manual that some brake fault codes are a "hard" code that fires the warning light and doesn't go away even if the problem is fixed until either the code is erased with a scanner or the engine is started and stopped 60 times.
Month or so later my lights finally went out and have been off for over five years, I did nothing.
Old Jun 16, 2006 | 08:46 PM
MBman's Avatar
holy $@!#, you gotta be kidding me! I guess I will wait, probably got 40 more starts
I did the breaker thing as well with same results as you
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
