manual trans additives??
Old Dec 4, 2007 | 07:32 PM
duallydave's Avatar
is there an additive for manual trans?mines been getting harder to get into gear since its been cold,the hydro fluid is full and trans is full too,just wondering if theres any additives for them.thanx
Old Dec 4, 2007 | 08:04 PM
Roperteacher's Avatar
The only one I have heard of that is good is the OPti Lube oil Improver. Supposed to work wonders in the Crank, Diffs, and Manual Trans. Reduces wear etc. etc.. I have some here and Was going to use it in the oil but thought I would wait a bit.. You add 3% by volume... Have yo switched the Manual trans to AMSOIL?? Mine sure shifted smoother after installing it. The opti Lube site is
www.opti-lube.com
Old Dec 4, 2007 | 08:07 PM
Spooler's Avatar
Is your truck a 2nd Gen as in signature? Really no need for additive if you are using synthetic as is recommended.
Old Dec 4, 2007 | 08:51 PM
ZachMI2003's Avatar
My '03 is becoming harder to shift as well. I'm gonna change the fluid pretty soon (@ 45,000 miles). We shall see if that makes a difference.
Old Dec 6, 2007 | 07:59 AM
leonesm's Avatar
I changed to Redline and it made a slight difference. The thing that really helped mine was the upgraded hydraulics. My stock equipment kept slowly getting worse and it got harder to shift. The hydraulic upgrade was a huge improvement
Old Dec 6, 2007 | 08:30 AM
MikeyB's Avatar
Personally I wouldn't put additives in the manual. Just run a high quality synthetic like from Amsoil or Redline. The big NV5600 is cranky when cold anyway so take your time shifting until it warms up. Should shift smooth as butter when warmed up.
MikeyB
Old Dec 6, 2007 | 12:05 PM
md-rebel's Avatar
Amsoil works great in mine, even this morning at 18 deg.
Old Dec 6, 2007 | 12:12 PM
DiEseLjunKy's Avatar
MikeyB
Me neither. Not even sure these kind of additives are meant to be used with ATF fluid they put in our modern manuals. Maybe it's ok for the ones using regular gear lube but imo if your shifts are real rough and a quality synthetic fluid isn't helping there must be problems bigger than what a good oil can fix...
Old Dec 6, 2007 | 04:47 PM
Hounddog's Avatar
NV5600 should work smooth as butter warmed up!
Old Dec 7, 2007 | 08:13 PM
duallydave's Avatar
no its the 04 in my sig,im not sure what type of fluid is in it now,maybe ill drain it and try the amsoil thing,is filling the trans somthing a backyard guy can do or do you need to take it in?thanx
Old Dec 7, 2007 | 09:52 PM
Equalizer 2's Avatar
It is something you can easily do. Just make sure you have a drain pan for the 4-5 quarts of oil that come out. Take out the bottom inspection plate bolt to drain it and then you might be able to get the inspection plate off by taking the rest of the bolts out. Then you can check and clean the magnet.
It takes a 17 mm hex to remove the filler plug but make sure you can turn it before you drain the oil that is in it. Make sure the oil that you get to refill it is campatible for the tranny, I think it is something like SynchroMax. I put in Royal Purple and the name is similar.
Free89W350
Dec 28, 2011 11:18 AM
badzj999
Aug 20, 2010 05:17 PM
fpr01
13
Sep 21, 2008 11:31 AM
djgaston
Oct 30, 2005 03:18 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
